Cool Tips and tricks - Page 16 - Ford Truck Enthusiasts Forums
  #226
Old 01-09-2012, 02:08 PM
Bozworth Bozworth is offline
Bozworth is gaining momentum as a positive member of FTE.
removed post
  #227
Old 07-17-2012, 12:03 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I had occasion to replace my rear spring pins and bushings. When I pulled my axle out I was shocked at how worn they were.
We all know the hand Ford dealt us on the Bonus Builts -- no access to the backside of the front pin. You can drill a hole in the crossmember that blocks access, but in my case, even if I did that, my exhaust would prevent me really getting a hammer on it. So...
I did some quick measurements, and found that a 3/8" bolt is real close to the right diameter for a 1/8"-NPT thread (what the zerk fittings use). So I took a 3/8" x 2-1/2" bolt, cut the head off, and tapped (died?) the plain end of the bolt. Tightened it into the zerk hole by double nutting, got it nice and tight. Slipped a 3/4" socket over the bolt, put a washer and nut on it. Tightened the nut and it broke the pin free and extracted it with no drama!
If I were going to do it again, I'd use a plain finish Grade 8 bolt, with fine threads, and possibly use a longer bolt so a deep socket could be used.
  #228
Old 07-17-2012, 11:23 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Had you rethreaded the bolt to 3/8 NPT (pipe thread) it would have fit better and not gummed up the threads in the pin. GOOD solution and tip tho!
  #229
Old 07-17-2012, 12:48 PM
ALBUQ F-1's Avatar
postin' fool
Quote:
Not sure what you mean? The zerk hole is 1/8-NPT, which is around 3/8" diameter. There's no way on earth to re-tap those pins, they are hardened steel. I figured the threads in the pin might pull out from the force, but they were undamaged.
  #230
Old 09-03-2012, 01:21 AM
medctr1's Avatar
medctr1 medctr1 is offline
medctr1 is starting off with a positive reputation.
checking out oil gauges ,compression on v8 flathead
Wow, what a good day. Checked out my flathead v8 239 . Compression tests showed good compression in all but cyclinders 5&6. Did a ?spash down test by squirting in some oil in each cylinder to see if compression comes up. It did not, stayed at about 50 in 5&6 while rest of cylinders at 105-110. So I guess I have two bad valves. Now the good news,my oil gauge always shows 60-80 and I didn't trust it. So removed the oil sensor and installed a mechanical oil pressure gauge (20.00 at o"reillys). Shows great compression at 50psi when warming up, then 40-45 when warm and 25psi at idle. I believe I have a pretty good engine, but need a valve job soon. Engine runs at about 185 F when warmed up.....
The discovery process is half the fun........or is it the backfiring going down hills......
  #231
Old 09-03-2012, 04:32 AM
petemcl's Avatar
petemcl petemcl is offline
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
Pin replacement trick
I tried this trick Ross. I even found some hardened all-thread so I was able to use a deep socket as you suggested. It worked on one pin but not the rest. I'll bet that works on most trucks but mine has really been abused and came out of Minnesota in the heart of the rust belt. The shackles were worn past the bushings (only half a bushing left) and the shackle body hoies were egg shaped. I was able to get the rear pins out through the hole in the frame but a cross member was in the way on my F-2 so I couldn't drill a hole in the frame in order to get to the front pin. I finally had to drill out the rivets holding the rear mounts in place. Once the mount was removed I could get the pins out.
This of course let me sandblast and repaint everything. But on reassembly I noticed that the 2 new pins that I got from C&G Early have a chamfer on the insertion end (opposite end from the Zerk fitting hole). They went in very easily. 4 of the original pins were OK but they did not have a chamfer and hung up on the inside hole. So I ground a slight chamfer on each and they fit in very easily.
Now the rear end is done and it is on to the front to install the toyota P/S box.
  #232
Old 09-03-2012, 08:27 AM
carnut122's Avatar
carnut122 carnut122 is offline
carnut122 is gaining momentum as a positive member of FTE.carnut122 is gaining momentum as a positive member of FTE.
$.25 to clean your engine compartment
I painted my kitchen cabinets this summer. Prior to the repaint, I had to degrease them (especially the tops which had about 20 years of grease and dust). I did an internet search for kitchen degreasers and many users recommended Totally Awesome (in the orange squirt bottle). It's sold at my local Dollar Tree. The stuff cut right through the kitchen grease like it was nothing. So, I bought another bottle for my garage and I've been using it to clean up my engine compartments where it works just as well as the Auto-parts store's engine cleaners in a can.
  #233
Old 09-03-2012, 11:21 AM
AXracer's Avatar
I use Simple Green straight out of the bottle.
  #234
Old 09-03-2012, 01:18 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
I've had good luck with Greased Lightning.
I've had engine brackets and other accessories with 30+ years of cooked on gunk come clean down to the bare metal after a few hours soak in the stuff.
Bobby
  #235
Old 09-03-2012, 02:19 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Quite possible you have nothing more than a head gasket leaking between cylinders 5&6.
Agree on the discovery process being the fun part. The downgrade after firing can usually be fixed.
  #236
Old 09-03-2012, 03:11 PM
medctr1's Avatar
No noticeable coolant loss so I figured it had to be a couple of bad exhaust valves in 5&6. I also thought the bad exhaust valves would cause backfiring. Also tried the paperbill trick on the tailpipe exhaust where
you put a paper bill near the end of the exhaust. It should just blow away from the exhaust pipe. If it blows away and comes back( a little bit back n forth), it indicates a burnt valve allowing suction in the exhaust system when its piston is in its downstroke. At least thats how I understand it.
  #237
Old 09-03-2012, 03:14 PM
medctr1's Avatar
No noticeable coolant loss or I figured it had to be a couple of bad exhaust valves. I also thought the bad exhaust valves would cause backfiring. Also tried the paperbill trick on the tailpipe exhaust where
you put a paper bill near the end of the exhaust. It should just blow away from the exhaust pipe. If it blows away and comes back a little bit, it indicates a burnt valve allowing suction in the exhaust system when its piston is in its downstroke. At least thats how I understand it.
  #238
Old 09-03-2012, 03:16 PM
petemcl's Avatar
Still Learnin'
No noticeable coolant loss so I figured it had to be a couple of bad exhaust valves in 5&6. I also thought the bad exhaust valves would cause backfiring. Also tried the paperbill trick on the tailpipe exhaust where you put a paper bill near the end of the exhaust. It should just blow away from the exhaust pipe. If it blows away and comes back( a little bit back n forth), it indicates a burnt valve allowing suction in the exhaust system when its piston is in its downstroke. At least thats how I understand it.
If you have a vacuum gauge this chart should help (old school high tech):
  #239
Old 09-03-2012, 03:21 PM
medctr1's Avatar
vacuum gauge
Thanks!!!I'll pick up a vacuum gauge today.....great chart
  #240
Old 09-03-2012, 10:45 PM
AXracer's Avatar
We diagnosed and tuned a LOT of engines at the service station with a vacuum gauge. My boss had one mounted in a plywood console along with a fuel pressure gauge and ammeter with a hook on it so we could hang it under the hood. It was the second thing that went under there right after the drop cord light when doing a tuneup.
short on primary wiring Redstop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 01-18-2016 09:45 PM
4 prong voltage regulator chasthanhburns 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-09-2015 06:03 PM
Fuel,temp,and oil gauge Wiring for 12 volt neg. ground Jeepcamp 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 12-05-2014 07:56 PM
12v to both neg and pos side of coil army89 1967 - 1972 F-100 & Larger F-Series Trucks 12 05-16-2011 09:23 PM
Gauge Electrical Short! potemkin 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 11-24-2008 11:00 AM
Tags
2002, 53, bolt, carriage, cooltips, f250, ford, frames, machinist, rails, remove, rusty, tips, trade, tricks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
