Cool Tips and tricks - Page 15 - Ford Truck Enthusiasts Forums
  #211
Old 03-01-2011, 01:35 PM
bobbytnm's Avatar
bobbytnm bobbytnm is online now
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Nice Bob
My drill press is one of my favorite tools
Bobby
  #212
Old 03-01-2011, 03:29 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
I've used my drill press as a makeshift milling machine a number of times. Chucked a rotary file in it and cut away.
  #213
Old 03-01-2011, 03:44 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is online now
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
Ax,
I've also done that a bunch of times. I have an ongoing project for one customer that I need to notch out PVC plumbing fittings and the rotary file makes the perfect notch. I lock the drill press head so the bottom of the file is about 1/2" of the table and go at it.
  #214
Old 04-13-2011, 11:49 AM
Alfie F-1 Alfie F-1 is offline
Alfie F-1 is starting off with a positive reputation.
Problem: you have a dashboard switch that will not accept the **** that you wish to use because the threads size is different.
For a lager thread size you can drill and tap the ****.
For a smaller thread, fill the **** you wish to use with epoxy, put some "antie-seize" on the threads of your switch shaft, place the **** on the shaft and let the epoxy harden. When the epoxy hardens the **** will screw on and off with no problem.
May also be used in other applications.
Alfie
  #215
Old 04-13-2011, 11:30 PM
AXracer's Avatar
JB Weld is a great metal filled epoxy for this type application, it can even be used to fill the ****, then drill and tap after the JBW has hardened.
  #216
Old 10-21-2011, 04:27 PM
john fin john fin is offline
john fin is starting off with a positive reputation.
FORD TRUCK TIPS and REPAIRS
  #217
Old 11-01-2011, 10:16 AM
Growler armature tester
Dont throw your money away on testers you may only use a couple of times.
HomeBrew Growler
  #218
Old 11-01-2011, 11:54 AM
AXracer's Avatar
We used a homebuilt growler like that at the service station I worked at many years ago to test starter and generator armatures. Size and angle the frame cut so the armatures will sit in the cutout suspended above the coil. Be sure not to nick the coil wires when you cut the frame! We would lay an old hacksaw blade on top the armature with the transformer coil turned on, and rotate the armature slowly under it. If the armature was shorted (bad) the hacksaw blade would vibrate. The setup also had a rudimentary homebuilt lathe for truing the commutator and hand cranked small saw blade that was used to undercut the insulator between the commutator segments. when business was slow, we rebuilt a lot of starter and generator cores that we had r&r'd on customer's cars. We'd test the armature, the coil, cut the commutator, replace the brushes and bearings, and wash and rattle can paint the outside of the case. Put it in a box on the shelf until needed. In those days we'd use 6.00 worth of parts, 1/2 hr of labor and resell the rebuilt part for 20-40.00, the going retail rate for a rebuilt from the parts store. For reference, I was being paid 1.20/hr to do the work at the time, so it was a nice profit (for the station owner...)
  #219
Old 11-01-2011, 12:49 PM
bobj49f2's Avatar
Exactly what I helped my dad do back in the '70s at his service station. I was about 10 years old and could rebuild a generic generator or starter in my sleep. I still have all his tools, growler and lathe but I'd be pretty rusty if I tried now but I think I could fuddle through it if I had to.
  #220
Old 11-01-2011, 05:39 PM
AXracer's Avatar
It's like riding a bicycle. I haven't done one in 40 years, but when I started thinking about it I remembered exactly how to do it.
  #221
Old 11-01-2011, 06:49 PM
bobbytnm's Avatar
Man, I havent used a growler since I worked at the Caddy dealership a gadzillion years ago...... ...I miss the days of rebuilding components; starters, generators, alternators, power steering pumps, master cylinders, steering gears, power brake boosters, etc
Bobby
  #222
Old 11-01-2011, 08:24 PM
Jag Red 54's Avatar
Jag Red 54 Jag Red 54 is online now
Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.Jag Red 54 has a very good reputation on FTE.
Wow, what a list of good ideas. Most of mine have already been posted by others, but here goes a real old basic. When using your bench grinder, keep the support edge less than 1/8" from the wheel. Also, while grinding, move the piece back and forth across the face of the wheel to keep the wheel flat and even. Good luck, Jag
  #223
Old 11-06-2011, 06:42 PM
adin adin is offline
adin is starting off with a positive reputation.
boys is it a major job to change my 1948 pickup to 12 volts
  #224
Old 11-06-2011, 06:57 PM
bobj49f2's Avatar
As long as your current wiring is in good shape going to 12 volt isn't a problem. The 6 volt is twice as heavy as you need for 12 volt. The only thing is you're going to have change all your light bulbs to 12 volt and insert voltage drop resistors before any 6 volt gauges, ignition coil and heater motor. You starter motor won't be hurt as long as you don't crank on it for extended periods of time.
  #225
Old 12-27-2011, 09:33 PM
Alvin in AZ's Avatar
Alvin in AZ Alvin in AZ is offline
Alvin in AZ is gaining momentum as a positive member of FTE.Alvin in AZ is gaining momentum as a positive member of FTE.
A tinkering fool like me loves this type of thread. :)
Quote:
Originally Posted by Truxx1956 View Post
Hey FORD guys! I find it aggrivating to install an automatic Ford trans to the
engine even in the floor out of the vehicle.Here's a good one: get the correct
thread bolts for the bellhousing(usually 7/16x14) get them about 2 to 3"
longer than the stock ones, cut the heads off of them, take a cutoff wheel,
and cut a slot in the end where the head was.Then simply use a slotted
screwdriver to screw them in.You really only need about 4 of them 2 at the
top and 2 at the bottom.
Here's a picture to go with Truxx's description...
...made those in '79 and dog-nosed 'em in '09. LOL :)
Alvin in AZ
ps- Automatic transmissions? ick! :P
'89 5.8L no start, no spark 1nwmike 1987 - 1996 F150 & Larger F-Series Trucks 8 04-15-2016 09:07 PM
S.O.S need help please read saauvenshine 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 04-03-2016 11:22 PM
short on primary wiring Redstop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 01-18-2016 09:45 PM
4 prong voltage regulator chasthanhburns 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-09-2015 06:03 PM
84f150 charging system blues doug84xlt 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 01-30-2004 04:04 PM
Tags
2002, 53, bolt, carriage, cooltips, f250, ford, frames, machinist, rails, remove, rusty, tips, trade, tricks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
