Cool Tips and tricks
#183
Here's a cheap and easy bead breaker I made out of a 2x8:
The box was built with very little clearance of the rim and the gussets were added to be able to cover as much surface of the tire as possible.
I used a piece of heavy steel under the rim (you can see it in the center of the wheel in the bottom picture) to wrap the chain around and then looped it over the port-a-power, you could substitute a floor jack. The wheels I dismounted were very old and glued to the rims and I couldn't beat them off. After I applied maximum pressure the beads popped, a couple took about 30 seconds under pressure but they finally popped. It worked on both sides and took maybe two minutes on each side.
#184
#186
#187
#188
MAKING PATCH PANELS
Probably not so new a trick but I will post it anyways. I had rust out above rear wheel wells of my panel truck, after cuting out the rust I had to make a template so I used Masking tape (Over laping each piece)to cover the cut out area. then I cut out the hole using a sharp xacto knife. Usinge the cut out area I have a very good template.
#190
First off, thank you for a very educational thread. Some things I already knew, but I've also learned allot of great stuff.
So here is my contribution.
I was changing out a rear axle by myself, in the dirt (sand). Lowered it out on the jack and drug it out on the jack. Easy enough, but then I had to push the new axle under the truck, by myself in the sand. What to do now?
Well I had some 10" diameter, 10' long pvc pipes for moving storage buildings laying next to the truck. So I put them under the truck inline with the frame and easily slid the axle under the truck and had plenty of room to position the jack under the diff. Easy as pie!
YMMV
YMMV
#191
#192
#193
Received 1,351 Likes
on
#194
Today I discovered that the rear brake hose for the 49 f1 is exactly the same as the rear brake hose for a 1971 9" rear. And, for those doing an engine upgrade from the original flatty you can have an extra 3 inches of space by placing the rad support on the forward holes. The inner fenders also have corresponding holes to accomodate this.
