Cool Tips and tricks - Page 13 - Ford Truck Enthusiasts Forums
  #181
Old 03-24-2010, 11:27 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
That's an EXCELLENT tip! thanks MP&C.
  #182
Old 03-29-2010, 02:36 PM
Stephen67's Avatar
Stephen67 Stephen67 is offline
Stephen67 has a good reputation on FTE.Stephen67 has a good reputation on FTE.Stephen67 has a good reputation on FTE.
MP&C I'm defiently going to remember that one!
  #183
Old 04-15-2010, 04:28 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
Here's a cheap and easy bead breaker I made out of a 2x8:
The box was built with very little clearance of the rim and the gussets were added to be able to cover as much surface of the tire as possible.
I used a piece of heavy steel under the rim (you can see it in the center of the wheel in the bottom picture) to wrap the chain around and then looped it over the port-a-power, you could substitute a floor jack. The wheels I dismounted were very old and glued to the rims and I couldn't beat them off. After I applied maximum pressure the beads popped, a couple took about 30 seconds under pressure but they finally popped. It worked on both sides and took maybe two minutes on each side.
  #184
Old 04-15-2010, 04:36 PM
BACAGrizz's Avatar
BACAGrizz BACAGrizz is offline
BACAGrizz has a good reputation on FTE.BACAGrizz has a good reputation on FTE.
Quote:
I hate it when I can't beat them off.
  #185
Old 05-19-2010, 04:15 PM
pony1966's Avatar
pony1966 pony1966 is offline
pony1966 is starting off with a positive reputation.
TIPS
GREAT TIPS. THANKS EVERYBODY.
MIKE
  #186
Old 05-19-2010, 07:21 PM
AXracer's Avatar
I have heard of using a strong vacuum pump and sucking the air out of the tire to break the beads. on a really stuck tire that you don't plan on reusing, a little heat applied to the rim until the bead starts smoking will release the oldest rubber bond.
  #187
Old 06-20-2010, 08:08 PM
Mervy49's Avatar
Mervy49 Mervy49 is offline
Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.Mervy49 has a great reputation on FTE.
Great thread going on here. I thought about this before also. I had to invent a couple tools at various times or find a picture of something I needed and fab it up. If I can ever figure out how to get pictures into a gallery I'll get them in there.
  #188
Old 08-16-2010, 02:41 PM
SCRAPHEAP51's Avatar
SCRAPHEAP51 SCRAPHEAP51 is offline
SCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to beholdSCRAPHEAP51 is a splendid one to behold
MAKING PATCH PANELS
Probably not so new a trick but I will post it anyways. I had rust out above rear wheel wells of my panel truck, after cuting out the rust I had to make a template so I used Masking tape (Over laping each piece)to cover the cut out area. then I cut out the hole using a sharp xacto knife. Usinge the cut out area I have a very good template.
  #189
Old 08-26-2010, 06:48 AM
Jinal Jinal is offline
Jinal is starting off with a positive reputation.
Thanks for nice information.........
  #190
Old 08-27-2010, 11:25 PM
sak778's Avatar
sak778 sak778 is offline
sak778 is starting off with a positive reputation.
First off, thank you for a very educational thread. Some things I already knew, but I've also learned allot of great stuff.
So here is my contribution.
I was changing out a rear axle by myself, in the dirt (sand). Lowered it out on the jack and drug it out on the jack. Easy enough, but then I had to push the new axle under the truck, by myself in the sand. What to do now?
Well I had some 10" diameter, 10' long pvc pipes for moving storage buildings laying next to the truck. So I put them under the truck inline with the frame and easily slid the axle under the truck and had plenty of room to position the jack under the diff. Easy as pie!
YMMV
  #191
Old 08-28-2010, 12:53 AM
sak778's Avatar
Another trick I use is for removing the metal particles from my welding magnets. I use silicone caulk from a caulking gun (cheaper than rtv) spread the caulk on the magnet and let it setup, then it peels away cleanly, encapsulating all the particles. Repeat as needed.
YMMV
  #192
Old 08-28-2010, 10:36 AM
AXracer's Avatar
I'm going to try that with my magnets. I usually brush off most of the particles with quick flicks of a stainless steel bristled welding brush. Since SS is non magnetic the particles brush off. It's not perfect, but it's quick.
  #193
Old 08-28-2010, 10:57 AM
Fomoko1's Avatar
Fomoko1 Fomoko1 is offline
Fomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputation
I use low air pressure for removing the metal particles from welding magnets, it`s not as safe nor is it perfect but it is quick.
  #194
Old 09-05-2010, 01:02 AM
Mervy49's Avatar
Today I discovered that the rear brake hose for the 49 f1 is exactly the same as the rear brake hose for a 1971 9" rear. And, for those doing an engine upgrade from the original flatty you can have an extra 3 inches of space by placing the rad support on the forward holes. The inner fenders also have corresponding holes to accomodate this.
  #195
Old 09-05-2010, 02:46 PM
firstrider's Avatar
firstrider firstrider is offline
firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.firstrider has a great reputation on FTE.
Then you will also need a I-6 hood air deflector if moving the radiator from the V-8 rear ward holes to the I-6 forward holes.
short on primary wiring Redstop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 01-18-2016 09:45 PM
4 prong voltage regulator chasthanhburns 1973 - 1979 F-100 & Larger F-Series Trucks 6 09-09-2015 06:03 PM
Fuel,temp,and oil gauge Wiring for 12 volt neg. ground Jeepcamp 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 12-05-2014 07:56 PM
12v to both neg and pos side of coil army89 1967 - 1972 F-100 & Larger F-Series Trucks 12 05-16-2011 09:23 PM
Gauge Electrical Short! potemkin 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 11-24-2008 11:00 AM
Tags
2002, 53, bolt, carriage, cooltips, f250, ford, frames, machinist, rails, remove, rusty, tips, trade, tricks, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
