Ford stromberg 2b ???
Old 09-10-2007, 06:42 PM
TryMe's Avatar
TryMe
TryMe is offline
Have not started it yet,but I just installed 3 rebuilt strombergs and a offy intake on my engine. And it looks great. But I do have a question ? I do have a high pressure/hi-volume fuel pump on it. And I was told I better install a fuel pressure regulator on it. The reason being he said that a stromberg only should have 3 to 4 lbs. of pressure to the carbs.Which I thought was not much. Anyone know what the fuel pressure should be on stromberg ???
THANKS !!
Old 09-10-2007, 07:33 PM
kotzy's Avatar
kotzy
kotzy is offline
The pressure of 3 to 4 is about right, those needle and seats and small floats were known for flooding. There is one thing that is overlooked, back when we ran them we didn't have good inline fuel filters or vitane needles, dirt was a big factor in our flooding problems. I would guess that if the needle is closed the normal Ford pump may have peaked at 6 or 7lbs. Kotzy
Old 09-10-2007, 09:54 PM
Snowking's Avatar
Snowking
Snowking is offline
Yes that is correct. He I would love to see a pic to this an chance of that happening?
Old 09-10-2007, 10:10 PM
effie_man's Avatar
effie_man
effie_man is offline
are your stroms hooked progressive or direct and did you change anything with the idle and tuel mixture etc with them. What im kinda getting at do you have one carb for idle, one for crusing and one for "fun" or are they all just hooked up directly
Old 09-13-2007, 09:11 PM
TryMe's Avatar
TryMe
TryMe is offline
The jets are 52. And the linkage is set up progressive. Running on the center carb. to a little less then 2 thirds open. Then the outside 2 kick in.
3/8 tubing fuel line flathead 2 chevy trans adapt. 5 speed
# 65 power valve 33/8 bore 4 " stroke
3 port t fuel port isky cam .364 lift - 249 duration
elec. ignition ignitor 50 ford heads
taylor wires smitty mufflers
fenton headers
the engine was rebuilt by a local rebuilder, the the owner failed to pick it up and pay bill. I purchased it like 7 months later built as is.
Old 09-13-2007, 09:14 PM
effie_man's Avatar
effie_man
im just gearing up for my build this winter
Old 09-13-2007, 09:47 PM
TryMe's Avatar
TryMe
TryMe is offline
So I take it the 53 is your winter project ?
Old 09-13-2007, 10:20 PM
effie_man's Avatar
effie_man
well i just got a 9" rear for it and im lowering it this winter. massaging the motor a little too. It runs and drives nice i just like to tinker with it lots lol.
Old 09-15-2007, 01:35 PM
TryMe's Avatar
TryMe
TryMe is offline
" EFFIE " Nothing wrong with tinkering. Its almost a daily thing with me. I have 2 that I built from the ground up and now I am into my 3 project. Hopefully it will be driveable at least around the neighborhood in a month. Pictures of mine have been posted on FTE, I guess about 6 to 8 months ago. I am not like most, I am into trucks that are not normal. What I am looking foward in building next is a 51 Ford school bus.
Currently I have A : 1950 Ford/Holmes F-6 wrecker. Its not a home made like
most. The beds made by holmes. Its a split boom truck,with
dual large pto winches, then 2 more to control the booms.
also it has factory outriggers. and a 12 lb pto winch behind
the front push bumper. Finished driving truck.
1952 Mercury truck. Its my pride and joy its a full size
4 door truck with a 8 foot pickup bed. Its a 1 ton dually.
Yes its long 22 ft bumper to bumper. With 11 1/2 ft running
boards between the fenders. Its a driving truck tags and all.
but needs a headliner and carpet. Its got 4 leather captians
chairs in it with a floor and over head center console. I am
not a interia person, Been looking for some one to tackle the
interia with out wanting a arm and a leg.
1951 Is the year I am working on now. and hopefully will be
done soon.
And yes I like to thank guys on FTE. Some of them have been very helpful in building these trucks over the last several years answering questions. I am not bashful, I do ask. Have a fun with your truck Later !!!!
Old 09-15-2007, 05:52 PM
effie_man's Avatar
effie_man
for the most part my truck is a nice runner right now but im putting 2 94 holleys on a edelbrock 2x2 polished intake with polished finned edelbrock heads. Im hoping for the 4 inch crank and an iskey max 1 cam. Id like to go 30-40 over and install performance pistons etc. Other than that theres the 9" rear with 3:73 gears, which is in process of being blasted and painted. Im taking out 2 leaves in the front and 3 in the back and switching oil pans to do so (mines a 53 car pan). Ive done a little sprucing up of the interior but still needs new kick panels, door panels, headliner, panels behind seat and window. They are an ugly green/yellow velour with black vinyl inserts right now, yuck! I need to get rid of my bi-ply tires too and rebuild my steering box. Hopefully that keeps me busy this winter. I get a lot of help from Fomoko1 (moderator of man/sask chapter) and a lot of other guys in the chapter. They are great!
Old 09-15-2007, 07:42 PM
Snowking's Avatar
Snowking
Snowking is offline
I don't get a honorable mention but Fom does, bah-hum-bug.
Old 09-15-2007, 11:23 PM
effie_man's Avatar
effie_man
hey man i said you were great. what more do you want. ill just keep your ozzy ticket then if you want lol
Old 09-15-2007, 11:27 PM
TryMe's Avatar
TryMe
TryMe is offline
Do you guys know my friend Bob Jones ? Hes into 49-52 Ford trucks also. He goes by " bobj " as a nick in FTE. Hes been a FTE member for a while. He also has his own ford truck web site,doing it by his self. Check it out. Hes got a lot of nice looking ford trucks on it. I think his web site is www.fatfendered trucks.com If its not get back with me ill get it. Also make sure you sign in his guest book, that away he knows a lot of guys are interested and been looking. And dont forget tell him I sent you. Thanks " Tracy "
Love to see more of you guys stoping by my shop for a visit. We don't make any money but we have fun.
Old 09-15-2007, 11:42 PM
effie_man's Avatar
effie_man
its the right address and i checked it out. I really like his panel
Old 09-15-2007, 11:53 PM
Snowking's Avatar
Snowking
Snowking is offline
You seriously were able to get them, did it sell out?
Is this off topic? sorry
Quick Reply: Ford stromberg 2b ???
