Victor Intake
Victor Intake
I wanted to get some opinions on what you guys thought a Victor Intake would do on my setup. Right now, I am running an Offenhauser Sing Four Tunnel Ram and a set of SCJ heads. I am planning on having the heads max ported so I've been thinking about switching over to the Victor Intake and getting it matched up to the heads at the same time. The engine is used for truck pulling. It is 498 c.i. 13:1 compression, and I run a roller cam over .700. Right now, the engine usually runs down the track around 7200, but I have had it up to 7500. Do you think a Victor would hurt/help performance?? I was thinking about buying a standard flange Victor and running my 2" inch spacer/adapter to my King Demon. Let me know what you guys think the pros and cons would be of making the intake change.
on
good intake for heavily modified stock heads. designed for high rpm use only.don't htink you will loose anything compared to the tunnel ram up top, might actaully gain a bit in the top, but will not be as torquey down low as compared to a tunnel ram (not that the tunnell rams are really a torque intake either, but better than a victor)
didn't say what carb you are running, but at those specs a dominator or equal is about the only carb going to be able to feed that motor.
never hurts to try, you can always go back and probably recoup most of the victor cost anyway.
rgds
Mike
rgds
Mike
I would get the Dominator flange intake. Then in the future if you upgrade to a dominator you'll already have the intake. I too think it will run better with a single carb setup. Your motor should turn more RPM than it is. I have a 463 with 14.1 comp. stock cast iron SCJ heads and a cast iron SCJ intake and a.724 lift roller cam and turn between 7500-8000 every pass with a 26.1 final ratio.
I've been thinking that I should be getting a little more RPM's out of it also. My final ratio is 27:1. Another guy that I pull with has a similar setup with a Victor and is getting more RPM's than I am also. My carburetor is a 1090 King Demon so it already has the 4500 flange. The intake has a single four top plate with an adapter/spacer to go from 4150 to 4500. Some people told me that the 2" adapter/spacer on the Victor would help performance, but I wasn't sure?? This is the first year out on the engine so we're still kind of dialing some stuff in. After the head/intake upgrade, I plan on putting it on the dyno so we can learn a little more about it. It would also give me an idea on what RPM range I am making the most power.
