burning trans fluid smell
you need to change your fluid, today.
get filter at ford if you can, drain pan and you must drain convertor.
remove the rubber plug and tap ignition until the drain bolt lines up.
use good fluid and a quart of lucas trans fluid.
you may be to late but this is worth a try.
describe the crap you find in the pan and on the magnet.
use brake cleaner to clean inside of pan.
My retired 92 F-250 7.3 Diesel had over 350K on it and 1 quart of lucas at oil change slowed oil burning from 3qts/5k to NONE.
YMMV
Good Luck,
Justin
of course it replaces a quart of regular trans. fluid.
i am talking about during a complete fluid change and filter.
disconnect the cooler line and drain a quart out.
i boil water in a pan and put the lucas bottle in so it thins out.
makes it easier to pour in.
this stuff is thick.
also, if you have convertor shudder i recommend shudder fixx, google it for more info.
it works and is only 5 bucks or so.
franchiworks
1983 - 2012 Ranger & B-Series
01-08-2017 03:53 PM
nohushhush
1999 to 2016 Super Duty
38
02-17-2015 04:05 PM
