Help with installing my stock air filter!?
Old 11-24-2007, 03:35 PM
wgm114's Avatar
wgm114
wgm114 is offline
On my 2001 5.4L F250 air filter, there is an arrow printed on the back of the rubber circular edge. It says "align arrow with notch" then points awkwardly toward the edge of the rubber circle. I thought maybe they meant the top notch of the plastic shroud but when I go to join the back part with the front part and clamp them, there is another picture showing "arrow placement" on the black plastic piece that mashes down on the rubber backing which is attached to the intake hose.
What arrow should match what notch? Furthermore, why? And does it matter which directioin the circular filter is installed with regard to rotation?
Help!
Old 12-29-2007, 01:42 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
I've never heard of issues with regards to which direction they are installed. As a matter of fact on several applications I've used it to my advantage, ever couple thousand miles changing the direction because it tends to load up in one area if you don't.
dborns
Escape & Escape Hybrid
07-07-2019 12:04 AM
jims94vmx
Fifth Wheel & Gooseneck RV Towing
03-31-2017 10:18 PM
nathan328
10-19-2016 01:48 PM
Moooboy
1999 to 2016 Super Duty
09-22-2016 08:04 PM
JohnnyAirtime
09-12-2013 10:58 PM
Quick Reply: Help with installing my stock air filter!?
