best air filter setup, V-10
Old 11-25-2007, 11:47 AM
rokhedjo's Avatar
rokhedjo
rokhedjo is offline
Question best air filter setup, V-10
any opnions on the best/ most sconomical/ best performance, etc.,etc.......
Old 12-30-2007, 11:22 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
I know the Outlaw Power CAI is a quality unit on my 5.4L.
Old 01-02-2008, 04:46 PM
wwb's Avatar
wwb
wwb is offline
Aside from full-throttle operation at the dragstrip, there is very little to be gained with an aftermarket intake system on a gasoline engine. Under normal operation, like 25% throttle or so, your throttle restricts the airflow FAR more than the intake system..... to the point that any reduction in intake restriction would be trivial or less.
A diesel is a different story.
Old 01-02-2008, 05:15 PM
rokhedjo's Avatar
rokhedjo
rokhedjo is offline
Some do filter air better than others I am sure, I guess a K&N filkter in the stock box will do.
Old 01-02-2008, 11:58 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
There has been a debate as long as I can remember, but a replacement K&N filter will not "filter" any better than a OEM Motorcraft filter. The only benefit of using a K&N (and such) is that it is re-usable.
Be careful when cleaning...as the oil based filters tend to dirty the MAF sensor causing poor performance.
IMO...the dry type filters are better. Here is what I recommend...
advanced FLOW engineering
http://www.afefilters.com/
OE Replacement Filter with Pro-Dry S
Ford Trucks (99-04) (gas)
Part Number: 11-10004
MSRP: $45.49
UPC: 80295911006
Shipping Weight: 2 lbs
Hope this helps...
biz
69redandwhite
05-08-2016 02:11 PM
gungolf4
05-13-2015 10:42 PM
SunBum
01-10-2010 09:40 PM
Raptor
Appearance & Dress-Up
07-21-2006 12:43 PM
atkalfayan
2004 - 2008 F150
17
05-04-2005 10:46 PM
Quick Reply: best air filter setup, V-10
