94 dually drum brakes removal
Old 09-06-2007, 09:37 PM
94' 460 F350's Avatar
94' 460 F350
94' 460 F350 is offline
well i got got my front brakes done, i got 2 new calipers and carbon pads, rotors didnt need to be resurfaced, i originaly had a mushy pedel you could push the pedel to the floor but it took some effort to do that, after the front brakes were done that helped, took it around the block and it was a big improvement but wasnt satisfying, felt like the fronts were the only ones grabbing hard
i bled the whole system at each wheel, now the back i kinda think there is no pads left considering the amout of wear the front pads had, if i slamed the brakes as hard as i could on gravel i couldnt even get it to "skid" and just felt like it was stoping slow,
so how do you get the rear drums off, any special tools needed i took out the axle and thats as far as i got it seems like you need a puller or a special tool to get the rest out??, i dont know why they just dont slide off
Dirrections form CHILTON'S CD:
loosen wheel brake shoe adjustment
it says to remove the wheel bearing locknut,washer, adjusting nut
remove hub and drum assemebly from axle
remove brake drum-to-hub retaining screws, bolts or bolts and nut
remove the brake drum form hub
Old 09-07-2007, 07:01 AM
96f150's Avatar
96f150
96f150 is offline
I just wen through this on my buddys 95 F250. I beleive you have the Ford 10.25" rear, which should be a full floater rear. You have to back that self adjuster off pretty far in order to be able to pull the drums off. Just remember that these are different from the 1/2 ton trucks, what I mean is, that in order to back the adjuster off you need to push in on the tab to allow the adjuster to loosen, the tab is on the BOTTOM part of the adjuster, not the top. Once you get it backed pretty far off, you should be able to take a hammer and wack them good to get them off.
Rich
Old 09-07-2007, 07:07 AM
jroehl's Avatar
jroehl
jroehl is offline
BIG hammer. To get my drums off, I was taking full swings with a 22 oz framing hammer with no success. I grabbed a 4 lb. engineer's hammer and just a solid tap took them right off.
Jason
Old 09-07-2007, 06:31 PM
94' 460 F350
Rich
i did back it off pretty far but i still dont think it is a floating drum
Old 09-07-2007, 06:47 PM
andym's Avatar
andym
andym is offline
You don't have to remove the axles in a 94 to get the drums off. The drums will come right off over the hub. If they don't come off easily, they will need some persuasion from a BFH.
Old 09-07-2007, 07:46 PM
94' 460 F350
alright im working on them right now, got the wheels off and slid the aluminum spacer off and it looks like i have to take out the 8 stud spacers/externders out? that sound right? i got one off and it looks like it threads into the other side if the drum i included some pics of my progress, am i doin it right?
Old 09-07-2007, 08:36 PM
96f150's Avatar
96f150
96f150 is offline
Yep, your doing it right....now soak some WD-40 around the studs and start wacking it from behind while turning the drum.
Old 09-07-2007, 09:02 PM
94' 460 F350
alright 10min after i posted the pics i got it off, i was supprised the pads were still in pretty good condition but had surface cracks, maybe the master cylinder for the drums are bad, i think im gonna replace the pads with some new ones and get 2 new master cylinders
Old 09-07-2007, 09:07 PM
96f150's Avatar
96f150
96f150 is offline
Good news!!! I'm assuming you meant wheel cylinders . I would definetly replace both wheel cylinders while your back there. The cracks maybe cam from excess heat buildup from towing maybe? How do the inside of the drums look? At the bare minimum, break the glaze on the inside of the drums before you put it back together.
Rich
Old 09-07-2007, 10:01 PM
94' 460 F350
yah i ment wheel cylinders ha ha, it looks like they are leaking a little so i am going to replace them, i think im gonna leave the pads alone, the inside of the drum looks great no groves at all, looks shiney(glazey) what should i use to remove the glaze, some sand paper like 150grit?
Old 06-07-2018, 11:39 AM
Eduardo Monjaras's Avatar
Eduardo Monjaras
Eduardo Monjaras is offline
F350
Where can I get the wheel spacers
Old 06-08-2018, 07:24 AM
humphrey169's Avatar
humphrey169
humphrey169 is offline
Pretty sure you have a single wheel axle so get the correct shoes and cylinders
Old 06-08-2018, 07:29 AM
Eduardo Monjaras
Do you know where I can get the Spacers again
GregN
01-26-2024 09:07 PM
BluGator2000
1997-2006 Expedition & Navigator
06-12-2020 06:56 PM
Surfcop
13
04-09-2015 12:08 PM
Lowe
07-12-2012 01:53 PM
Camphill
09-28-2008 08:54 AM
Quick Reply: 94 dually drum brakes removal
