Transmission Problems E4OD - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 06-29-2014, 10:57 PM
West f150 302 5.0 West f150 302 5.0 is offline
West f150 302 5.0 is starting off with a positive reputation.
I have similar problems I was told vss and pcm could be bad
  #32
Old 06-29-2014, 11:09 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Quote:
you were not told wrong.those are possibilities.in the vast amount of possibilities,those are some of the more rare ones and not a decent starting point,but true enough phrase in it's own right i suppose.
the codes and a new thread are the best places to begin.
E4od not shifting into gear after a long trip Encho 1987 - 1996 F150 & Larger F-Series Trucks 19 02-20-2016 03:26 PM
E4OD delay into drive stevenjf88 1987 - 1996 F150 & Larger F-Series Trucks 3 10-28-2015 11:39 PM
e4od transmission not shifting idihillbilly Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 07-04-2015 07:00 PM
5R55E Transmission problems sknaggs185 Clutch, Transmission, Differential, Axle & Transfer Case 2 03-19-2009 11:59 PM
5R55E Transmission problems sknaggs185 New Member Introductions 1 03-17-2009 11:06 PM
Tags
1995, 1996, 94, change, drive, e40d, e4od, f150, fluid, ford, gear, located, problems, sensor, speed, speedometer, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
