Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 09-06-2007, 08:05 PM
07EXPYEL 07EXPYEL is offline
Garage is empty, add now
07EXPYEL is starting off with a positive reputation.
Transmission Temperatures
Has anyone installed a transmission temperature gauge or used a OBD computer to measure the transmission temperature? One of my gripes of the Expedition versus the Suburban is that the Suburban message display will show the transmission temperaure, but the Expedition does not. I have the heavy duty tow package, but I'd really like to know that the transmission isn't running too hot with my 30' #5,500 (loaded) travel trailer running in the AZ heat loaded with my family of 7. I don't understand why Ford didn't program this into the message display since the data is already in the computer already. Personally I think this is a purposely witheld feature that will be added in a later years and promoted after all the new model buzz has faded.
  #2 (permalink)
Old 09-15-2007, 01:11 AM
Newton007's Avatar
Newton007 Newton007 is offline
Newton007 is starting off with a positive reputation.
I wondered this too as I have the tow package also. It would be nice to know as towing on long steep grades, going through heavy snow can really increase transmission fluid temperatures.
I never lost a transmission just to steep grades alone on dry pavement, but lost a C4 and a C6 going up grade through several miles of deep snow. I think the, slower engine speed, slow car speed in low gear = less transmission cooling even with a add on heavy duty fluid cooler.
Had a Allan Root built 460 on one side of the B and M C6 and heavy snow with tire chains on the other side of the B and M C6. The transmission rubber cooler lines got so hot they just snapped into when bent.
When I pulled the C6 apart, the shafts got so hot they turned blue and the clutch packs would NOT come apart even when I tried using a hammer!
The transmission was not rebuildable. Just scrap metal.
After this, I always put a temperature gage in the transmission pan, then if I seen it going a little over temp while under a load, would just stop in park and run the engine at a fast idle until it cooled down and then went on.
Never had another problem after that. It was money well spent.
  #3 (permalink)
Old 09-08-2008, 09:22 AM
I'm just posting a link to my thread about tranny temps
http://www.ford-trucks.com/forums/72...eadings-3.html
Tags
temperatures, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
