FORD SIX 300 ignition wiring DIAGRAM
Hi,
I and some friends have a FORD SIX 300 that is out of a UPS truck (1987 ?).
We are installing it into a small engine (as in railroad) that will be used to move around a small track system in an old logging / sawmill yard.
It is installed and after a few more additions like radiator, battery, exhaust and COIL w/ IGNITION MODULE it will be ready to start.
I need a wiring diagram that shows what feeds into the ignition module as well as what wires go between the ignition module and the coil.
The engine has a carberaror and is built around 1987.
The distributor is part marked: D5TE 12127 FA (there is a 2E 27 above the rest of the numbers but I have been told they are not part of the part number).
The ignition module is a: DY184C. (two connectors - one with two wires, one with three wires)
I would appreciate it if someone can tell me what diagram would work with this combo & where to find it.
Thank you in advance for any information the group can provide.
Try this site:
http://www.jason.fletcher.net/tech/d.../duraspark.htm
Its for a 302, but the set-up is the same.
Edwin
Edwin
dyingtolive
297
05-24-2021 09:15 PM
xtal_01
12-02-2016 12:36 AM
StoneHarding
07-10-2016 11:00 AM
JoeHarbourJets
13
04-14-2011 09:35 AM
