Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Appearance & Dress-Up SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 09-06-2007, 02:53 PM
1980F15049's Avatar
1980F15049 1980F15049 is offline
1980F15049 is starting off with a positive reputation.
Door Skins
I'm looking to replace my door skins? Where can I find door skins, and how hard are they to install? Instructions if possible.
  #2 (permalink)
Old 09-06-2007, 06:26 PM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
Any body shop or even wrecking yards have access to aftermarket parts . Hey there may be a vendor in your area . I have 2 in 70 miles rad. RAYBUCK parts in Pa treat me good..
They weld on and crimp bend around edges. I don't have trouble finding 80' 90's doors in good shape so the extra work isn't worth it for me. I live in rust belt of PA
__________________
Red Neck rule #1 If you drive a truck you should always be looking for trucks to get parts off of. If you can't find part used you aren't looking hard enough.
94 F150 XLT 4x4 SC LB MAF 302 E4od 3:55 ls rear
MSD blaster coil ,cap rotor ,Fordracing 9mm wires
  #3 (permalink)
Old 09-06-2007, 07:10 PM
ReAX's Avatar
ReAX ReAX is offline
2002 Ford F-250
ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE. ReAX has a great reputation on FTE.
Inner or outer. It's usually easier to swap the whole door for the outer unless you have lots of time and equipment available.
Inner door panels can be had from coverlay.
__________________
Too many mods to list, so click here.
Here are my tech write ups
Look, see these two tow hooks? They look like tusks. And what kind of animal has tusks?
  #4 (permalink)
Old 09-06-2007, 08:11 PM
1980F15049's Avatar
I have tried the junk yard so many times and never seen an "good" door all are worse than mine
  #5 (permalink)
Old 09-06-2007, 09:31 PM
ReAX's Avatar
2002 Ford F-250
Check with your local body shop. Shipping sheet metal is PIA, it often get damaged because the shipper's don't package them well enough. However, they may have a supplier with a private truck, and shipping odd get much better than with a common carrier.
__________________
Tags
door , f250 , ford , raybuckparts , skins
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
