injectors split vs single shot. - Ford Truck Enthusiasts Forums
Old 09-06-2007, 02:45 PM
mustang_gt_350 mustang_gt_350 is offline
mustang_gt_350 is starting off with a positive reputation.
Just wanting to know the benefits of both? What is good for what application? I got my truck use a few months ago and it has 235k miles on them. And i'm sure they are original with nothing done to them ever. So i was thinking of rebuilding them with one of the DIY kits and maybe just doing the nozzle upgrade or converting them to single shot 180's but not sure and would like some info on split vs single.
Old 09-06-2007, 02:56 PM
driximus's Avatar
driximus driximus is offline
driximus is gaining momentum as a positive member of FTE.driximus is gaining momentum as a positive member of FTE.
The Single Shot will require less High Pressure oil and will be a better choice if you have a stock HPOP.
Old 09-06-2007, 03:08 PM
driximus's Avatar
almost forgot you will need custom tuning for the single shots.
Old 09-06-2007, 03:21 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie PowerstrokeJunkie is offline
PowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to beholdPowerstrokeJunkie is a splendid one to behold
A single shot injector has a louder idle, it will sound exactly like the 94-97 powerstrokes, if you ever heard one idle up close. Some people like it, but some like it quiet. They do use less oil volume than a comparable single shot, about 20-30% less oil i've heard. The reason for that, on a split shot injector, there is a port in the side of the intensifier piston barrel where the oil pressure is exhausted out of the side of the barrel, to pause the fuel injection very briefly ("split" shot), and then once the plunger strokes far enough, the port is closed and then fuel injection begins again. So during this pause in fuel injection, oil is being used however no fuel is being injected. Single shot injector doesn't have this port and it's just one injection event. They also seem to be cheaper, but you'll NEED a chip to run the engine with single shots. If you have a problem and have to remove the chip, your engine can still run stock with split shots. When i do injectors, they will be single shots.
Old 09-06-2007, 04:09 PM
GregN's Avatar
GregN GregN is offline
GregN is gaining momentum as a positive member of FTE.
I have been wondering the same thing. Which one is better for mileage?
Old 09-06-2007, 04:27 PM
John311t John311t is offline
John311t has a good reputation on FTE.John311t has a good reputation on FTE.
They say singles are better for MPG, but CSI said that they didnt change on bit.
Old 09-06-2007, 04:48 PM
Thanks kris. Thats just what i wanted explained to me. I'm still a diesel newb.
Also kris. I thought i would have to have it programmed for them but wasnt sure. So could DP reflash my stock pcm to run a stock tune for the singles and then stack the chip on like normal so that if i had to pull the chip i would be able to run without it then?
Old 09-06-2007, 06:11 PM
jtharvey's Avatar
jtharvey jtharvey is offline
jtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to alljtharvey is a name known to all
I don't see why Jody couldn't flash your PCM and then have a chip on there as well. I just put singles on mine, and I'm one of the ones that likes the different sound. I'll be checking MPG this weekend to see if there's a difference.
Old 09-06-2007, 06:36 PM
Mr. Bob's Avatar
Mr. Bob Mr. Bob is offline
Mr. Bob is starting off with a positive reputation.
I want to do single shots around x mas... thinking 160cc with nozzle upgrades.....
CL find, Swamps injectors. Seller knows nothing about them. Robert6401 1999 - 2003 7.3L Power Stroke Diesel 20 12-08-2016 12:25 PM
Single or split shot injectors? DougJ_1997PSD 1994.5 - 1997 7.3L Power Stroke Diesel 8 04-06-2015 09:17 PM
Single shots with stock tunes brwolfjr 1999 - 2003 7.3L Power Stroke Diesel 8 05-14-2013 11:02 PM
single shot vs. split shot? fordman67 1994.5 - 1997 7.3L Power Stroke Diesel 13 06-17-2012 09:48 PM
Better mileage: Single or Split shots? Kwikkordead 1999 - 2003 7.3L Power Stroke Diesel 15 08-27-2005 11:21 PM
Tags
9497, diy, explained, f250, flash, ford, hybrid, injectors, pcm, powerstroke, shot, shots, single, split, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
