top speed on 1951 ford f-8 big job? - Ford Truck Enthusiasts Forums
Old 09-06-2007, 09:57 AM
89ford73's Avatar
89ford73 89ford73 is offline
89ford73 is starting off with a positive reputation.
i was just wondering about how fast the truck would run in high gear with a direct drive transmission running around 3,000 rpms.
Old 09-06-2007, 09:59 AM
89ford73's Avatar
10.00-20 tires with a 6.50 ring and pinion
Old 09-06-2007, 10:35 AM
52merc's Avatar
52merc 52merc is offline
52merc is starting off with a positive reputation.
Depends on the O.D. of your tires - assuming a 6" sidewall that would be about 32" tall. Works out to around 45 mph.
It is fairly easy to calculate:
3000 rpm(direct drive)/6.50(Rear Gear ratio) = 462 RPM for your rear tires
Rear Tire Circumference(outside) * 462 rpm = Speed in inches/minute
Divide by 63360 to convert inches to miles.
Multiply by 60 to convert minutes to hours.
gives you miles per hour.
Mike
Old 09-06-2007, 11:27 AM
F100Slammer's Avatar
F100Slammer F100Slammer is offline
F100Slammer is starting off with a positive reputation.
Online calculator
Here is a link to an online calculator. Just enter the data in the cells, click calculate, and scroll down to see the chart.
http://www.wallaceracing.com/gear-speed.php
Larry
Old 09-06-2007, 01:14 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.HT32BSX115 has a great reputation on FTE.
I did that same calculation (using higher math!!.....actually junior high-school math!) My 9.00-20 tires measure out to about 40"(3.33') diameter.
I calculated that I would need to have a rear-wheel rpm of 504 rpm to get 60 mph. (with a 0.7 OD)
Simply calculate the rolling circumference[C=Pi x Dia] of the tires.
C = 3.14 x 3.33'........10.47 ft.......1 mile is 5280 ft.....60 mph is 5280 ft/min.......
Then divide the rear tire circumference into 5280! 5280/10.47 = 504 (rpm)
504 is rear wheel rpm needed to go 60!
Now multiply 504 times the rear axle ratio to get drive shaft RPM to go 60.
504 x 5.83 = 2938 rpm and using the 0.7 OD....2056rpm!
All you need to know to make this work is the rolling diameter of the (rear) tires, Which you can measure and the rear axle ratio (and OD ratio if installed)
Cheers,
Rick
Old 09-07-2007, 01:56 AM
John - NNY John - NNY is offline
John - NNY is starting off with a positive reputation.
My 1948 F7 will do about 60-65-ish. My spedometer isn't very reliable so it is just a guess. Once I get past 50-ish, the front end starts to shake and thump and I get the *******. It has the 337 flathead in it. It has a singe speed rear and 20" tires.
John
NNY
WHAT WEIGHT OIL ARE YOU RUNNING IN THE FE's ford390gashog FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 105 12-04-2015 03:01 PM
Ford CPS dn29626 1999 - 2003 7.3L Power Stroke Diesel 15 09-05-2012 09:24 PM
1978 ford f250 bamboo321 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-01-2012 10:42 PM
tire psi cory5517 1999 - 2003 7.3L Power Stroke Diesel 36 03-26-2012 06:34 AM
FASS Fuel Pump Ford Powerstroke Diesel gt40racing 1994.5 - 1997 7.3L Power Stroke Diesel 4 03-16-2011 07:14 AM
Tags
1948, 1951, 337, big, direct, drive, f8, fast, ford, job, log, parts, sale, sparkplugs, speed, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
