Still No Start
#32
You can get it direct from Autoenginuity. Here is a link to the order page. http://www.autoenginuity.com/order.html
#33
#34
#35
Originally Posted by Blankie
I'm back. Got my auto Enginuity Scan tool today. Loaded software in Laptop, Connected to truck as per instructions. Message said ScanTool could not connect to vehicle. Has anyone had this problem. I do have the Ford enhanced version. HELP!!!
#36
on
1 Post
#37
#38
#39
Some reading for You....
C1 DIAGNOSTIC TROUBLE CODE (DTC) P0113
G1 CLEAR AND ATTEMPT TO REGENERATE DTC P0344, P0341 OR P0340
AJ1 DIAGNOSTIC TROUBLE CODE (DTC) P0606: INACTIVE BACKGROUND FAULT
<TABLE cellSpacing=0 cellPadding=3 width="92%" border=1><TBODY><TR><TH width="50%">Yes </TH><TH width="50%">No </TH></TR><TR><TD width="50%">REPLACE PCM. </TD><TD width="50%">System OK. RERUN Scan Tool Diagnostic Test to see if there are any other stored DTCs. </TD></TR></TBODY></TABLE>
Z1 DIAGNOSTIC TROUBLE CODE (DTC) P1280: ICP CIRCUIT LOW INPUT
- DTC P0113 (IAT) indicates that the corresponding sensor signal circuit is out of range high.
- Possible causes:
- open in harness
- worn or damaged connection
- worn or damaged sensor
- damaged PCM
- NGS Tester installed.
- Key on/engine off.
- Access IATV PID (voltage).
- Plug in NGS Tester.
- Clear Continuous Memory DTCs with NGS Tester.
- Crank engine while monitoring RPM PID.
- DTC P0606 exists only when there has been an internal failure of the PCM.
- Rerun Scan Tool Diagnostic Test. Note: If DTC P0606 is retrieved with other DTCs, service all other DTCs first.
- DTC P1280 indicates injector control signal circuit out of range low was detected during KOEO Self Test or during continuous diagnostic monitoring.
- Possible causes:
- biased ICP sensor/PCM
- open ICP sensor circuit
- short to SIG RTN or PWR GND on ICP sensor circuit
- open in VREF circuit
- Disconnect ICP sensor connector.
- Measure voltage between VREF Pin B and battery ground.
#42
