Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 09-12-2007, 11:58 PM
Kemicalburns's Avatar
Kemicalburns is gaining momentum as a positive member of FTE.Kemicalburns is gaining momentum as a positive member of FTE.
no problem, check out www.fordfuelinjection.com for more info
__________________
94 XLT 5.8/E4OD
6"ProComp Stage II 35x12.5x15 BFG MT's ,
4.88 gears f/r
installing soon: JBA shorty, Bassani Y pipe, Edelbrock efi truck intake, , aussie front/rear
88 (Rolled)
http://www.supermotors.org/registry/vehicles/detail.php?id=4158
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 09-13-2007, 08:37 AM
jostephy8 is starting off with a positive reputation.
any chance the oil pan from the lincoln will work in the truck? the truck pan has a couple of holes in it! :^(
  #18 (permalink)
Old 09-13-2007, 08:41 AM
nope it wont work but finding a 4wd 302 pan should be plenty easy and not very spendy. check all the local yards and if nothing comes up check out ebay i see lots on there as well.
__________________
94 XLT 5.8/E4OD
4.88 gears f/r
88 (Rolled)
  #19 (permalink)
Old 09-13-2007, 11:37 AM
Its just 2wd.Does that make any difference?
  #20 (permalink)
Old 09-13-2007, 03:46 PM
then the pan may fit.
__________________
94 XLT 5.8/E4OD
4.88 gears f/r
88 (Rolled)
  #21 (permalink)
Old 09-25-2007, 01:27 PM
mitchec01 is starting off with a positive reputation.
90 Lincoln MK VII is not speed density- it's mass air. My donor was an '89 MK VII, and it was mass air. Don't know if this makes any difference- probably not if you are keeping the truck injection and just using the Lincoln block.
  #22 (permalink)
Old 10-26-2007, 01:21 AM
RacinNdrummin is new and has a neutral reputation at this point.
Quote:
News to me, every MK VII ive ever seen up to 92 has been SD.
__________________
74/71 maverick grabber EFI HO (under construction)
05 ranger 3.0/5spd supercab
90 Bronco II, 4.0 swap (UC) 5-speed, 4x4, factory D35
6" lift 33's 8.8...
91 Mustang LX 5.0 Coupe (new engine being built now)
91 E250 4.9 c6 3.73
95 F-150/SB/SC 351w swap, 3.55, 4r70w (Dads truck)
  #23 (permalink)
Old 10-26-2007, 05:31 AM
5851a is starting off with a positive reputation.
Kemical burns is correct on all counts AFAIK.
  #24 (permalink)
Old 11-04-2007, 06:49 PM
Sorry- I forgot that we had taken the harness and computer out of a Mustang and put it on the Lincoln block.
  #25 (permalink)
Old 12-20-2007, 12:01 AM
ford4life69's Avatar
Uwasa Wahya
ford4life69 has a very good reputation on FTE.ford4life69 has a very good reputation on FTE.ford4life69 has a very good reputation on FTE.
Quote:
Originally Posted by hoxiii
Something else to look out for is the imbalance on the flexplate. Bear with with me, but there are about to be alot of IF's coming out here.
I know that when you run a manual transmission, car and truck flywheels are different diameters. IF the same goes for flexplates, you're going to have to run your truck flexplate on the 302HO. Now, IIRC the 1986 f-150 uses a 28oz flexplate while the 302 HO uses a 50oz flexplate. This means IF the flexplates are different diameters, you'll have to find a 50oz flywheel that fits the truck transmission.
BUT, if the HO flexplate and the 302 flexplate are the same tooth count, ignore everything i've put up here.
Just figured i'd give you a heads up since i know a guy that put a 28oz truck flywheel on a 302 HO and promptly wiped all of the bearings out of it.
Justin
How promptly did he wipe all the bearings out of it because i think that's exactly what i've done (put a 28 oz on i mean) on the 1980 302 i've just put into my 79. the mechanic that i had time it (that's how i found out it's got a 302 ho cam in it because he figured out the firing order) and when he got it running he said it needed a different flexplate but he didn't know which one and that it would be ok to drive it the five miles from his shop to my parents house to change the flexplate myself since he's going on extended vacation for the holidays...... you think five miles at low speeds (like around 40, it was worst at about 1200 rpms and smoothed out above that) is enough to destroy the dumb thing?
__________________
Thanx!
Connie
Down to two, the Bullet an Ol' Blue
'79 f100 "Silver Bullet" (my baby)
'85 f150 "Ol' Blue" (my next project)
MORE
Military Online RElay
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
