Sand Blasting
Sand Blasting
Ok... newbe question (again).
I built a blaster cabinet (like Earl's) and am getting ready to set up the "air"... I want to lubricate my air tools... but I'm thinkin I should use a separate "line" to run the blaster... don't want no oil on the blasted iron...
Am I thinkin right?
Duh, me...
Am I thinkin right?
Duh, me...
Just turn down the oiler and use the same hose you use for your other tools. You always want to wipe down fresh metal with a metal cleaner/mineral spirits/alcohol to clean off finger prints and other contaminants before any paint. Most compressors put some oil out so the air is never going to be pure/clean air. The cleaning step will be necessary regardless of which tool oiling technique you decide to use. If you plan to do any painting down the road, I'd keep that hose system away from the oiler and add a good water filter/seperator.
Steve, I think you have it right, run another line. Why introduce oil somewhere you don't want it? Plus the sandblasting effect will leave a not so smooth finish which will make it more difficult for your precleaning steps prior to painting to remove everything. Additionally, I don't put anything oily or grease covered in my blast cabinet for the same reason. Degrease the parts before blasting.
