Regular fuel to Racing fuel???
To many variables to set a number. Cylinder design is the biggest, the tolerances of the build (Quench etc...) Then there is the cam, piston design, vehicle weight, gearing, intended use, tuner capability. Finally, there is the quality of the fuel itself. Racing fuels are not created equal either.
The masses seem to believe around 9.5:1. However there are production factory cars with 11.5 . Which is also about where I prefer to run on choice head designs 91 With my bikes I run 13-14:1. The vehicles in your sig could range from 9:1 to 11:1.
It is best to specify a motor and pull from sources on what they have done and why. Pay the most heed to those who have measured (cc'd), recite actual CR numbers, degreed cams etc...
Mike you should add Octane Boost to your tank. Continuing to run low octane without retarding the timing will burn pistons out. I would bump your metering jets up on the carb by a min of 5#, maybe even 10. This will also make it run better on pump gas. Went through the same things years ago on my 360 when my dad gave me the truck. Pinging constantly on pump gas and it was low compression.
Your engine also requires LEADED FUEL. You should also add a lead substitute to keep from damaging you valve guides and seats. Unless you have had your heads reworked.
Or get some 140 octane Aviation Fuel.
Mikeb
Look at the CR issue and the lead requirements as two issues.
CR
The alchohol, Toluene or any other chemical will help handle the CR, but will most likely need tuning to use. Toluene works wonders, already in gas at the pump, likely in an octane booster, and its primary purpose is to raise octane level. Does have drawbacks and cautions with use and handling.
Fattening up the carb tune will cause more heartache than fix. Lowers combustion temps which helps valves and seats. But costs in engine life etc...
Lead,
I would not concern with the guides unless you decise to start racing it. I use amco45 guides and despize steel, but many use steel and are happy with it. yours are most likely loose enough to be fine.
Most importantly, you are aware and are not running the motor at higher power. It will run for many years as you are doing now. Just as thousands of other old car owners who cruise occasionally.
AVGAS is actually lower in BTUs than most automotive fuels, but it is also required to sit for 12 months in the tank without degredation. Given how little you drive the car. that could be a big advantage. Lot less "gumming" from old gas.
Enjoy that T-bird for us will ya
CR
Lead,
peakster
01-06-2015 10:17 PM
zachsherman88
05-08-2009 12:49 PM
