New Jersey Chapter Join Chapter Leader: sddesigns
New Jersey Tradin, Selling thread
Old 09-24-2006, 03:22 PM
kevincw's Avatar
kevincw
kevincw is offline
351w roller motor
It's a 1989 or 1990, 351w EFI out of a Bronco. Complete minus the front pullies and brackets. $500
Old 10-03-2006, 05:02 PM
frederic's Avatar
frederic
frederic is offline
1993 F-series Red Vinyl Bench Seat $10
Red Bench seat, good condition, with two working headrests. Fits 87-96 plus earlier cabs I imagine.
Tracks not included. Contact directly. Cleaning out my garage, and I'd hate to haul this to the junkyard for them to just resell and rape someone.
Thx.
Also have faded blue F-series hood (92-96) with large 4' wide x 2' deep hole cut into it, framed with angle iron. Good for sticking turbos through the hood - FREE!
Old 10-22-2006, 12:09 PM
gearshift101's Avatar
gearshift101
gearshift101 is offline
1986 F-150 Xlt 2wd For Sale
Sale Price $350.00 can be used for parts or make it a daily driver / project/ work horse.
I have a 1986 F-150 2wd XLT with strong running 351 v8 winsor engine with a 1406 edlebrock carb the engine has less than 83000 mi on it, 3 speed automatic c-6 tranny, 9" 3.00 ratio rear (3rd member). with new axle bearings and seals, new rear pinion seal, new u-joints replaced this summer 2006, summer of 2005 I replaced the the frnt coil springs, shocks, tie rod ends, hub rotors, calibers, brakes, upper and lower ball joints, and two new frnt tires. the frnt end is solid. I also replaced the starter.
This truck is in good running condition and passed NJ State inspection in February 2006 sticker good til 2008.
It has AC that blows cool can use a charge, power windows work, power locks that don't work?, cruise control works, tilt steering, oil pressure gage not working (May just need an oil pressure sensor) has good compression and don't burn any oil. I've done oil changes every 25 - 3000 mi and tune ups every fall. has the split/sliding rear window, duel fuel tanks, for which the rear tank has been diconnected tank is fine just removed the switch and never replaced it, so I only use the frnt tank. all lights and electrical work fine, has a windshield sunshield, has a sunviser shelf with eyeglass, change holder, napkin holder, no sun visors. door panels are missing a couple of fastener along bottom edge. exterior: needs paint, has large dent on the passenger side of the bed behind the wheel, a dent on the tail gate which the handle is not working to open it, there is rust on the roof but no holes, and minor rust in some spots nothing major easy fix.
My reason for selling: This summer I had a rear pinion seal leak. I replaced the seal, when I went to reinstall the drive pinion and yolk/flange I did'nt count the turns it took to get the pinion nut off, so on istall I may have tightend the pinion nut to much, or when I replaced the axle seals and bearings I didn't reinstall the break assembly correctly causing the rear to lock up when driving I truly think it's the breaks. there is no noise when driving just lock up. then I would put it in nautral and rock the truck and the wheels will unlock. so after this test run I brought the truck back to my yard put the jack under the truck to check the breaks.
and Bang! I went to the hospital with a heart attack.
Now I can't do any work on the truck and must sell it. you can read all my post for this pinion job I attempted to do. If the problem is in the drive pinion you may need to replace the crush sleeve, for which I may have crushed a little bit too much. That's it.
If interested I can email pictures to you.
Thanks for looking
Al
Old 03-02-2007, 11:20 PM
rods4life's Avatar
rods4life
rods4life is offline
1990 Bronco For Sale in NJ
Selling my 1990 5.8 XLT Bronco. Truck runs but needs work. I use it as my everyday driver. Can be a fixer uper or a parts truck. Email me if your interested and I will give you the run down. I will also be placing a ad on the site in the near future.
Rods4life1954@aol.com
Thanks
Al
Old 03-03-2007, 11:21 AM
mrfox0246's Avatar
mrfox0246
mrfox0246 is offline
looking for a bench seat for my '54 F100, and headlight buckets from a 55-56.
Heck, I'm looking for lots of things, wadda ya have?
I'm in Dover, Northern NJ
Thanks
Rich
Old 03-10-2007, 06:22 PM
DVM04's Avatar
DVM04
DVM04 is offline
Part needed
Local member looking for a rear fuel tank filler neck. I have an 83 f-150, flareside that has no opening for the rear fuel tank. (must be a replacement bed). The front tank has a fuel door, but my rear tank neck is blocked off and nothing enters the flareside. I am looking for a complete neck from the attachment to the wheel well, gas cap and hoses so I can use my rear tank. Thanks in advance. I am located in Matawan nj
Old 03-16-2007, 08:48 PM
twisted289's Avatar
twisted289
twisted289 is offline
Hey guys, just wondering if anyone out there has a set of stock f250 CC leaf springs with low miles on them, collecting dust in the corner, taking up room in their garage. In need of a new home
Im looking at doing a spring swap on my EX. Anyone near NJ that wants to get rid of them, let me know how much and where you are. Thanks in Advance, John
Old 04-09-2007, 04:43 PM
mrfox0246's Avatar
mrfox0246
Free to a good home
Cleaning out the garage. Have a 70's vintage Ford 360 FE motor, basically the block, heads, valve train, no intake manifold. Came out of a truck; never been disassembled, been on the engine stand for last 10 years. Located in zip code 07801. PM me if you're interested
Old 04-11-2007, 07:49 AM
NJ2000R's Avatar
NJ2000R
NJ2000R is offline
I know its short notice, but I've been very busy at work and just thought to post on the forums....if anyone wants a 1991 F250 Diesel 4x4 for the driveline, one of my employees was in an accident, and although the truck is probably beyond repair, the engine, trans, axles, etc are good and the truck was always maintained very well. Its on ebay and ending soon, reserve met at $999.00 which is a heck of a deal for a 7.3L diesel....
http://cgi.ebay.com/ebaymotors/ws/eB...0462411&rd=1,1
Old 06-21-2007, 07:50 PM
JJPMach1's Avatar
JJPMach1
JJPMach1 is offline
wheels & Tires 4-sale 10,000 miles
I got new wheels for my truck and am selling the OEM's. They have 10,000 miles and I can meet you just about anywhere to drop them off. No plugs or flats and mostly highway miles. I'm looking for $850.00 for the set.
http://i106.photobucket.com/albums/m265/JJPMach1/Car%20Stuff/S7300482.jpg
http://i106.photobucket.com/albums/m265/JJPMach1/Car%20Stuff/S7300481.jpg
http://i106.photobucket.com/albums/m265/JJPMach1/Car%20Stuff/S7300480.jpg
Old 06-29-2007, 07:42 PM
captchas's Avatar
captchas
captchas is offline
Guest
front chrome bumper for 05 to 07 f250/350. front and rear bumpers for a 05 up mustang v6 model. 07 wind veil blue color. front is complete with the grilles and fog lamps. will seperate. , front part of the wheel liner goes with the bumpers.
free guys just pick them up at my home.
Old 07-10-2007, 08:55 PM
ranger1999 Bob's Avatar
ranger1999 Bob
ranger1999 Bob is offline
i have a longbed ranger leer cap im looking to get rid of its grey with a yakima rack on it has locks and is in decent shape located at my upstate house ill take $200 for it pick it up in Deposit NY
Old 07-22-2007, 07:11 AM
captchas's Avatar
captchas
captchas is offline
Guest
304 polished, ss, mac performance mufflers 4 inch tips for a 05 up mustang gt, $275.00 for the pair. on the car 3 days then off. cost me 400.00.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: New Jersey Tradin, Selling thread
