spare tire stuck - Ford Truck Enthusiasts Forums
spare tire stuck
Old 06-30-2002, 04:00 PM
4x4300i6 4x4300i6 is offline
4x4300i6 is starting off with a positive reputation.
spare tire stuck
i was cranking up the spare tire into the holding spot under the bed of my moms 97'f150 when it hit the top all the sudden something snaped and the tire will not come back down and trhe bar to lower just spins in the hole and the tire doesnt move at all
DOES ANY ONE KNOW WHAT HAS HAPPEND AND OR HOW TO FIX IT????
DAVID TONKIN
Old 06-30-2002, 05:28 PM
spare tire stuck
all fixxed
Old 07-11-2002, 09:18 PM
bosshoss bosshoss is offline
bosshoss is starting off with a positive reputation.
spare tire stuck
Hey David. The part that pulls the tire up, or down is most likely broken. You can have a friend crank the tire down while you pull down on the tire, that might work. You can buy the crank and cable unit from ford. I dont have the part number right now, but i can get it. Note, when cranking the tire back up KEEP THE LIFT CABEL TIGHT.
Let the cable pull the tire back under the truck a little if need be. A lose cable will wrap up lose and cause a lock up problem.
Dave Powell
Old 07-12-2002, 12:34 AM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
spare tire stuck
what does stx mean ??????????? kewlf150 Ranger & B-Series 8 07-18-2014 01:30 PM
how hard would it be........ 4x4300i6 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 08-27-2002 07:15 PM
spare tire mounts dbarracuda 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-03-2002 10:09 PM
300 i6 rebuild questions 4x4300i6 Ford Inline Six, 200, 250, 4.9L / 300 6 07-07-2002 01:13 PM
what does stx mean ??????? kewlf150 1987 - 1996 F150 & Larger F-Series Trucks 3 05-23-2002 03:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
