oldfart have a safe trip - Ford Truck Enthusiasts Forums
Pennsylvania Chapter Join Chapter, Leader: liftnw8z
Old 09-02-2007, 05:05 PM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
Have a good trip if not left yet . I was up there today nosing around . No see. But will look tomarrow after I'm done with tune up. later lost aka larry
Old 09-03-2007, 11:47 AM
oldfart oldfart is offline
oldfart is gaining momentum as a positive member of FTE.
Quote:
Aye Lost left Greencastle, Pa. at 4a.m. Sat. arrived in Curwensville, Pa. at 7:30a.m.! Fog was turrible from Tyrone all the way to Curwensville! Wound up being a 2 day job. Till we got done ripping off all the bad lumber all we had left was the rafters! Installed new o.s.b. on after raising the rafters 6in.!! to get the roof/rafters level and proper fall to the rear again! WAGH! Then installed the new metal roof panels. A word to the wise here..if considering replacing any kind of roof..go with a metal roof!! The metal roof panels are cut to whatever length is needed and cover 3ft. wide. Once the rafters were prepared the installation of a 16X24ft. roof took about 1 hour...including beer breaks. Try that with shingles! And due to the lack of "fall" on this roof it was the best way to go as well. Shingles don't last long on a roof without much pitch. Metal lasts forever. Now on another subject..arrived at my folks home after driveing 125 trouble-free miles and went to back up into the driveway and as soon as I went from Drive to Reverse that ole 86 Ford F-150, 302, A.O.D. E.F.I. just croaked! (as in stalled, shut down without as much as a stumble) Hmmmm?? Go figger? It started right back up and ran fine the entire 125 miles back home. Of course that was 125 miles of spincter-clenching concern just waiting for it to stall on the Tyrone Mountain or in traffic somewhere on the way home! Nothing much puts a knot in yer shorts as having a vehicle problem 125 miles from home..eh! Stalling and croaking on the Tyrone Mt. or coming off Bailey Rd. (90deg. hill with a house at the bottom!!) sure gits ye frettin'! Any ideas would be most welcome! All in all..a safe journey and a job well done. Audie..the oldfart...
Old 09-03-2007, 02:56 PM
You meen you actually stop at the bottom ?? Well glad it work for you . Both truck and roof. I'm a shingle and rubber roof man my self . Have had to fix to many metal ones .
But if house i think it was it looks good .
You have my number keep in truck If you have problem while in transit I'll come get you.
trip a/b 2011 150 jimmyt 2009 - 2014 F150 1 05-14-2013 09:07 AM
FYI---MPG joeyd61 1999 - 2003 7.3L Power Stroke Diesel 10 03-20-2011 02:07 PM
Bad Mpg On Trips To Fla. Rafiki2cu 6.7L Power Stroke Diesel 17 12-11-2010 11:26 AM
Road trip slmann Missouri Chapter 27 08-24-2006 08:58 AM
Towing with F150 Supercrew karenj Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 21 08-04-2004 08:16 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
