Set Ignition Timing 1996 4.9l F-150 - Ford Truck Enthusiasts Forums
Old 09-02-2007, 10:01 AM
joe.mcfadden joe.mcfadden is offline
joe.mcfadden is starting off with a positive reputation.
Hello All
Today I Want To Use My Timing Light To Set My Ignition Timing On My 1996 F-150 4.9l. Do I Have To Disconnect Any Thing? Like In The Old Days When You Somtimes Had To Disconnect The Vacuum Advance. My Truck Has No Vacuume Advance So Im Wodering If There Is An Electronic Connector To Pull Prior To Changing The Timing. The Remainder Of Task I Know. Thanks
Old 09-02-2007, 10:15 AM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
the spout is a plug you need to remove.
it is right around the distributer and is usually grey.
10 degrees btdc is the setting you should set to with spout out.
welcome to fte.
Old 09-02-2007, 12:01 PM
Spout As In Connector? I See Two Diferent Connectors Small Type One Comes Off The Coil, The Other Goes To The Block. Im Still At Least 100 Degrees Off Using The #1 Spark Plug Wire For The Pickup. Thanks For Getting Me Started.
Old 09-02-2007, 01:35 PM
DrBones[LCD] DrBones[LCD] is offline
DrBones[LCD] is starting off with a positive reputation.
Check for a plug w/a grey connector at the ICM (Ignition Control Module), which might be fender mounted (driver's side) on your truck.
Old 09-02-2007, 03:07 PM
quicklook2's Avatar
this is a good time to buy a manual.
it will help for things like this and other harder problems.
Old 09-02-2007, 03:46 PM
Wynn96 Wynn96 is offline
Wynn96 is starting off with a positive reputation.
Wait. I have a 96 and the spout is NOT near the distributer. It drove me nuts. It is by the driver side hood hinge, and it has two pink wires going into it. You have to pull the gray plug from the end of it and don't lose it.
Old 09-02-2007, 04:18 PM
quicklook2's Avatar
different engines have them in different places.
Swap 1987 4.9l to 1996 4.9l Differences/Issues 77bronco87 1987 - 1996 F150 & Larger F-Series Trucks 5 02-08-2015 10:32 AM
How vacuum advance affects gas mileage 101. 1986F150six 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 04-29-2014 02:51 PM
1996 4.9L PCM OBDII danr1 Ford Truck Parts for Sale 0 04-08-2014 10:12 PM
Carter YF vacuum ports [vacuum timing adjustment] 1986F150six Ford Inline Six, 200, 250, 4.9L / 300 10 02-25-2013 01:21 PM
DTC P0174 TOO LEAN LEFT BANK 1996 F-150 4.9L EFI joe.mcfadden 1987 - 1996 F150 & Larger F-Series Trucks 1 01-16-2012 09:44 PM
Tags
1987, 1996, 49, 49l, 96, adjust, base, f150, ford, ignition, l6, rpm, set, spout, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
