6.4L PSD exhaust brake
#32
Originally Posted by dave at BD Power
We are testing the 6.4L brake now and is working for the most part, we are get a few check engine lights which we will need to develop some electronics for much like the 6.0L. I would expect to see the release in time for X-mas!
So...is the exhaust brake basically the same (design etc.) as the 6.0L version? Or did you guys have to do a complete re-design? I figured the electronics would be different...
biz
#33
Originally Posted by biz4two
Now that is what I was hoping to hear!
biz
biz
shhhhh, don't tell anyone but we took the 6.0L brake and bolted it right on the 6.4L and what da ya know it worked LOL. Like I said it set some check engine lights and the transmission was not down shifting like we would like to see it so we have to re-develop the tranny controller (Auto Loc) eletronics and some electronics to correct the check engine lights.
#34
I was under the impression that none of the exhuast system could be legally modified. Will adding the exhaust break void the warrenty? Will it also get you in trouble with CARB?
#35
Originally Posted by 1968gtcs
Hi Dave
#36
Hi Dave
We are not modifying the exhaust per say, installing a valve in the system can be argued and modifying I guess. Warranty is up to the dealer/manufacture, we have no say if after markets products will void your warranty or not. The Magnuson Moss Act clearly states they can not void your warranty if the after market product was not proven to cause a failure but that is an up hill battle to say the least!
Its the been that way for ever, after marker products vs manufacture warranty, some dealer are friendlier than others.
#39
biz
#40
This is also the first year for smog crap on the Diesels. I was under the impression that you could not modify any of the exhaust from the Turbo's back to the exhaust tips. If you do modify it then the device would need to be CARB certified. California seams to have smog police every were. In 4 years I believe owners of the 08 truck will more than likely have to go through a smog station to renew there registration.
I would not mind having the exhaust break on my truck Every little bit of breaking helps. To bad you did not have it available several months ago. I could have given it a good test pulling 19Klbs from California to Alaska and back.
biz4two
10-08-2005 04:54 PM
