Go Back   Ford Truck Enthusiasts Forums > Diesel > Competition
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Competition Diesel racing, sleds, dynos, power tuning and max performance.
  #1 (permalink)
Old 09-01-2007, 05:50 PM
mustang_gt_350 mustang_gt_350 is offline
Garage is empty, add now
mustang_gt_350 is starting off with a positive reputation.
sled pulling help...
Ok guys. I think i am going to take the jump into pulling 1 pull this fall to get the feel of it for the begining of next year. I just want some tips. And also i have a question. The question is Do most of the pulls provide the plug for the reciever hitch or do you have to bring your own??? and if so where to purchase one???
Ok as for the tips. I am runing the factory size 235/85/16's with stock 3.73 gears. I know to pull in low range but i'm not sure on what gear to start out in. should i start in manual 1 or 2? and shoud i let it shift? This will be my first hook with any truck (or anything for that matter) and just want to have an idea of what gear i should go with. I was watching pulls last weekend and i noticed that the ones that were pulling a higher gear faired much better than going with the low grunt gear. I do understand that you have to make power to pull the higher gears. but i think 2nd would be enough. So any help i would be grateful for I would like to go and have fun i'm not expecting to win as i'm not runing a DP tuner or anything just a 10k mod. But i want to go there trying to win so i will not be tip toeing down the track when hooked.
thanks
__________________
late 99 reg cab 4x4 4r100
www.DIY-injectors.com
Idm info (updated 3/17/08)
http://www.shol.com/shadow_tech/idmmod
  #2 (permalink)
Old 09-01-2007, 09:22 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch is a name known to allstrokin'_tatsch is a name known to allstrokin'_tatsch is a name known to allstrokin'_tatsch is a name known to allstrokin'_tatsch is a name known to allstrokin'_tatsch is a name known to all
not sure if i would use 4 Low or 4 high. try 4 high for the track speed and lock out in 2nd. this should give you plenty of track speed before the sled gets you.
__________________
Travis- Death Row Diesel Inmate #7
1995 F-250 RC 2wd PSD ZF5- 500+hp daily driver.
1994 F-150 4x4 408w- 10.5:1, TFS heads, custom cam, etc.
  #3 (permalink)
Old 09-01-2007, 09:59 PM
Thats what i'm stuck on trying to decide. I think it might be better on the truck by letting the transfercase do the work by gearing and keep the wheels spining when the sled gets me instead of having it bog down. But i have never done this before so its just thoughts.
__________________
  #4 (permalink)
Old 09-01-2007, 11:08 PM
b/c you have small tires you will most likely spin them easily, so when the sled gets you... then the tires will spin. the more track speed you can get before then, then the more momentum you will have when the sled gets too heavy for the truck, which will make you go farther. whatever you do, do NOT let it go in drive or else the tranny may be toasted.
__________________
Tags
diesel, f150, ford, hitch, kind, pulling, pulls, sled, tips, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
