Brake light don't work - 02 excursion need help!
Brake lights don't work - 02 excursion need help!
Hi, on our 02 Excursion, the brake lights in the tail light housings do not work, but the third brakelight up above does work. The blinkers work. All the fuses under the dash have been checked out. I checked the 5 wires going into the brakeklight switch. 2 are hot all the time, 2 others are hot only when the brake pedal is depressed.
What should I check next?
Thanks, Joel
Thanks, Joel
Tilt the steering wheel, and see if they start working. If they do, then you have a wiring plug in the column that has too much strain on it, and is making a bad connection. If that doesn't fix it, I suspect your multi-function switch may be bad.
Since your third brake light is working, that means everything down at the pedal switch is ok. The rear brake lights go through the turnsignal switch (multi-function switch).
joel79ford
03-25-2012 11:34 PM
Joel Steven
08-30-2005 09:39 AM
