Help quick...stabbing distributor
Are there any tricks of the trade? The distributer is not seating down on the block and I'm afraid to use a mallet. I'm having trouble stabbing the distributor pump shaft in a 5.8 '94 . Everything is marked and scribed and transferred to the rebuilt distributor. Nothing has been moved. Motorcraft numbers match. Part number from Cardone is correct. However, bottom end of the old shart is about 5/8" longerr than the new one. I measured from the pump shaft to the block and the new looks like it should work fine. The cam gears mesh fine and rotor rotates about an hour when lowered but I dont think the end of the distributor shaft is going in the pump shaft hole. I'm guessing the longer shaft allowed stabbing the shaft then the gear instead of vice vesus.
Celebration time...got the correct distributor now
I tried another auto supply chain. They had one with 1 1/2" from gear to the end of the shaft like the original. The end 5/8' or so is smaller diameter. It slipped right in less than five seconds. The pump shaft stabbed first then I could still turn the rotor to stab the gear correctly. I spent an hour trying to make the shorter shaft work yesterday. Same part number from the same remanufacturer from an unopened box. It is purring away during warmup to set the timing and pumping oil. Time will tell if this corrects the intermittent dying.
thesuperbad234
18
08-26-2016 05:13 PM
59INA40
11-27-2005 04:37 PM
jls73
08-15-2004 09:40 PM
302, 400, 50, 87, distibutor, distrbutor, distributor, f150, flathead, ford, frontmount, longer, shaft, stab, stabbing
