A/C ducting stuck in defrost position
I have a 2005 F-250 6.0 Diesel King Ranch and the a/c ducting selection buttons quit working. Normally, I just start the a/c by pushing the "Auto" button...but yesterday, when I did that, the a/c began blowing out the defrost vents at the windshield. Once I noticed this, I pushed the button to select the split floor/face vents...but it won't switch. Further attempts to change it to any other setting don't work either.
Does anyone know whats going on with this???
I had same symptoms. Actually, my vent would shift to defrost under engine load, then back to vent... Seems that when you mash the pedal the vaccum level drops. I would have expected just the opposite, but appearently there is something else using the vacuum pressure when under load.
Anyway, mine turned out to be in the vacuum solinoid for the ESOF. It was cracked and leaking a good bit. It is under the hood. Not exactly sure where since the dealer fixed it. Shouldn't be too hard to find - just follow the vacuum lines from the hubs up.
If your vent stays on defrost all the time that might tell you something - you have a larger leak. This can be good news since the smaller ones might not be as easy to find.
If not the solinoid I know there is a bit of vacuum piping under the dash - behind the glove box.
Of course, this all assumes that you have any vacumm at all. The pump could be going or gone. I don't know if these things will run with little or no vacuum.
So I have a similar problem that I'm still trying to narrow down... My vacuum is working fine, and is seemingly getting good vacuum all the way to the vent actuator behind the glove box (not sure what it's actually called). The problem is, when I change from defrost to floor, it never makes it to the floor position. It can make it to the dash vents, but seems to move the lever just short of the optimum position to completely close the defrost vents and fully open the dash vents.
My question is... does this mean there is not enough vacuum (I'm not sure if the vacuum level actually determines vent position or some other mechanism?) OR does it mean a problem with the actuator OR maybe the vent lever mechanism is requiring too much force to move???
Incidentally... it seems as though, even when the dash vents are fully engaged, I'm just not getting the airflow I think I should on MAX fan... Does anyone else think the blower is weak on MAX or is it just me?
Had this EXACT issue on my SHO. AC was blowing out the defrost. Delaer said it was fine (my LAST visit to them...). The vacuum motor/actuator thingy under the dash was bad. Proved it by pulling a vacuum on it and trying to move the actuator/hearing the leak. It will be obvious if that is the issue once you pull it. Just remember - please - verify the part is bad before you replace it...BTDT too many times.
-Dave
-Dave
