Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 08-30-2007, 11:56 AM
berry1234's Avatar
berry1234 berry1234 is offline
Garage is empty, add now
berry1234 is gaining momentum as a positive member of FTE.
Brakes Pulling to the left
Just wanted to post some more info on this in case anyone else has this problem. My 2007 EB 4x2 with 4,000 miles pulls to the left while braking at freeway speeds. The dealer has replaced pads, turned rotors, disabled ABS, etc with no luck. It is at the dealer now and I will keep updating this post as I find out information.
  #2 (permalink)
Old 08-31-2007, 04:31 PM
berry1234's Avatar
Update: Talked to the service manager at the dealer I have the truck at. We went on a test drive and the car pulled while braking at freeway speeds. He thinks it is the right front caliper. He thinks as it heats up a bit it is sticking. The problem is under visual inspection all the brake components look fine. He said all parts replaced that appear normal have to be sent to Ford and if they are found not to be defective the dealer is back charged. So, what this means to me is I have to take one more test drive in a few days, he will record the problem and then Ford will approve the replacement of the caliper. Pain in the azz, but whatever it takes.
  #3 (permalink)
Old 09-06-2007, 02:57 PM
berry1234's Avatar
Another update: Took another test drive and the engineer has narrowed it down to the rear right caliper. After it heats up it hangs and does not grab equally with the left causing the pulling. Monday morning parts should be in and lets cross our fingeres.
  #4 (permalink)
Old 09-07-2007, 11:58 AM
berry1234's Avatar
Well it looks like the caliper is on nationwide backorder...Hmmm.... Bad engineering? Hopefully it will be here within a week.
  #5 (permalink)
Old 09-07-2007, 12:27 PM
pugster pugster is offline
pugster is starting off with a positive reputation.
Wink Pulling Brakes
Have the dealer replace the phenolic caliper pistons w/ aftermarket steel pistons. If he won't do this, insist he r&r the calipers and polish the existing pistons if possible.
  #6 (permalink)
Old 09-07-2007, 04:55 PM
berry1234's Avatar
Quote:
Ford aint gona do nothing but replace the parts with exact OEM replacements. They can barely do that.
  #7 (permalink)
Old 09-14-2007, 04:24 PM
berry1234's Avatar
Update: I got the truck back and it appears the truck is fixed! Cross your fingers. I need more time on the freeway, as the traffic was bad. Here is a list of what they did.
A T103 VEH PULLS TO THE LEFT WHN BRAKING AT FREEWAY SPEEDS.
CAUSE: 6245 TEST DROVE, REMOVED WHEELS & INSPECT BRAKE SYSTEM. FOUND
RIGHT REAR CALIPER HANG-UP, REMOVED RIGHT REAR CALIPER & REPLACED. BLEED BRAKES.
REPLACE CALIPER ASSEMBLY. PART # 7L1Z*2552*A
I will post another update Monday morning or sooner as I have to drive 300 miles on the fwy this weekend.
  #8 (permalink)
Old 09-14-2007, 11:35 PM
Newton007's Avatar
Newton007 Newton007 is offline
Newton007 is starting off with a positive reputation.
Thanks for the information. No problem here, but I am watching for any brake problem on my 07.
  #9 (permalink)
Old 09-17-2007, 10:49 AM
berry1234's Avatar
Scratch that. Brakes still pull! When they were deciding which caliper to replace the foreman was 50/50 whether to replace the front or rear. Well, another trip back to the dealer.
  #10 (permalink)
Old 09-24-2007, 12:04 PM
Baumbach Baumbach is offline
Baumbach is starting off with a positive reputation.
I had the same brake pulling issues for the first 5,000 miles, but at about 5,500 miles it stopped pulling and they also seem to work much better (stronger) . I now have just over 7k miles so no pulling in the last 1,500 miles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
