Synthetic Replacement for 5w20
Most big syn makers have a 5W20. I prefer 5W30 syn jus tbecause I think it starts up a little quieter, but could be imagination.
No reason to run anything like xW40 or 50 unless you have an egnine bruning oil in which case syn is probably a waste anyway.
I don't care for 0Wxx since in my experience it does make the engine noisy at startup and there is no real good reason fo it in my opinion unless you live where block heaters are standard equipment.
Just my opinion,
Jim Henderson
Just my opinion,
Jim Henderson
In case you have engine problems & seeing as how you have a 07 & likely a Warranty to consider, be sure the lube you use, says on the contaner, that it Meets or Exceeds Fords specifications & stay within the owners manual viscosity range call out, for the temps you'll encounter & for the type of driving you'll do, during the OCI, down in hot country AZ.
Texaco & Chevron make good lubes, that should be available in your part of the country, if you don't want to use Motorcrafts full synthetic.
Just another thought or two for pondering.
BigBlocker0248
02-08-2016 04:02 AM
