TSB 07-7-2. Anyone done it?
07-7-2 REAR OF VEHICLE IS TOO HIGH/LOW - 5TH WHEEL AND GOOSE NECK APPLICATIONS - 4X4 VEHICLES ONLY
Publication Date: March 26, 2007
FORD: 2005-2008 F-Super Duty
ISSUE:
Some 2005-2008 F-Super Duty vehicles my exhibit a clearance concern when using the vehicle to tow some goose neck and 5th wheel trailer applications.
ACTION:
Follow the Service Procedure steps to change the rear ride height.
SERVICE PROCEDURE
Rear ride height may be reduced or increased by:
Lower - vehicles that have the 4" (10 cm) spacer block by installing a new 2" (5 cm) spacer block along with the other rear suspension hardware
Raise - vehicles that are perceived as riding too low (no spacer block installed) by installing a new 2" (5 cm) spacer block along with other rear suspension hardware
LOWER VEHICLES WITH 4" (10 cm) SPACER IN PLACE
Raise vehicle on hoist and support rear axle.
Remove rear axle U-bolts and nuts.
Lower rear axle and remove 4X4 rear axle spacer blocks.
Place new spacer blocks (Figure 1) on axle and raise axle to bottom of springs, seating springs in axle seat.
Install new rear axle U-bolts and nuts (Figure 1). Torque nuts to 185 ± 28 lb-ft (250 ± 38 N-m).
Remove rear axle shock absorber bolts and nuts, and remove rear shock absorbers.
CAUTION: DO NOT OVER TORQUE SHOCK ATTACHING FASTENERS.
Install new rear shock absorbers (refer to Figure 4 and 5 for correct application). Torque both upper and lower shock nuts to 62.5 ± 9.5 N-m (46 ± 7 lb-ft).
NOTE: FAILURE TO UPDATE THE CENTER BEARING BRACKET (FIGURE 2 AND 3), IF REQUIRED, MAY RESULT IN DRIVELINE SHUDDER.
If necessary, install new center bearing and/or shim (refer to Figure 2 and 3 for correct application) assembly as required.
For checking driveline angles, refer to the Workshop Manual (WSM), Section 205-00.
Adjust headlamp aim by referring to the WSM, Section 417-01.
RAISE VEHICLES WITHOUT 4" (10 CM) SPACER
Install new rear axle U-bolts and nuts (Figure 1). Torque nuts to185 ± 28 lb-ft (250 ± 38 N-m).
Replace rear axle brake jounce hose assembly with new assembly, refer to the WSM, Section 206-00.
If vehicle is equipped with a rear suspension stabilizer bar, replace rear stabilizer bar links with new stabilizer bar links. Torque stabilizer link nuts to 70 ± 15 N-m (52 ± 11 lb-ft).
Bleed rear brake system by referring to the WSM, Section 206-00.
For checking driveline angles, refer to WSM, Section 205-00.
NOTE: RIDE HEIGHT ISSUES RELATED TO A CUSTOMER'S TRAILER ARE NOT COVERED UNDER WARRANTY.
I have an 06 F250 and just recently purchased f350 spacers and u bolts. I havent swapped them out yet b/c i ran across this and was wondering if anyone has done this at the dealer? How much?
ISSUE:
ACTION:
SERVICE PROCEDURE
Upper Rear Shock stud stripped - over torque
Sir, Just joined. Missed the all caps "CAUTION-DON'T OVERTIGHTEN." And, I misread the Haynes manual and tried to put 77lbs on the upper mount. Now the stud is stripped. Bracket is riveted to the frame and I cannot get the nut to back off the stud. Do you or anyone else know how to get it off now.
I think if I could get the nut off, I could build it up with a couple of washers and use remaining threads on the end of the stud.
Otherwise it looks like have to grind off the bracket and fit something new in place.
ideas?
Vr/ ATRMG1610
ideas?
Vr/ ATRMG1610
2civicrr
6.7L Power Stroke Diesel
09-17-2015 11:54 PM
250andEX
04-08-2015 07:19 AM
