Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Canadian National Chapter > Ontario Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ontario Chapter Join Chapter>, Leader: loudfords
  #1 (permalink)
Old 08-29-2007, 07:11 PM
ness0012 ness0012 is offline
Garage is empty, add now
ness0012 is starting off with a positive reputation.
Need Custom Driveshaft
So this is pretty self explanitory, I need a custom D-shaft for my f-150 thanks to my custom 8" double main leaves in the back. Anyone ever had a custom d-shaft made? I'm looking for a company near Ottawa or Cornwall (I'm inbetween) preferably. also anything I special I should consider or look out for?
Thanks loads
Andrew
  #2 (permalink)
Old 08-29-2007, 07:53 PM
sewerat's Avatar
sewerat sewerat is offline
sewerat is gaining momentum as a positive member of FTE.
I had a custom drive shaft made for my bronco one time. who i used was 401 mack dealer here in windsor but what i would do if i were you would be go see one of the big truck shops and ask them who is good to use . Also talk with them about the drive shaft length and angles as i have heard that a drive shaft length should be no longer then .... i am not sure what the length is but at that length you need to look at putting in hangers.
hope that helps some
  #3 (permalink)
Old 08-30-2007, 07:07 AM
fp_5's Avatar
fp_5 fp_5 is offline
fp_5 is starting off with a positive reputation.
Try and find a drive train shop that specializes in axles, differential etc. A 4x4 shop could at least recommend someone if they can't do it.
Or maybe you can find a longer one and have shortend? I had my drive shaft shortend by a local shop in Pickering, great guy. Cost me 75 bucks including two new u joints!
Frank
__________________
'76 F100
'64 Falcon
'47 & '48 Ford Fordor Super Deluxe
'77 F250 Super Cab
" I thought I was wrong once but,...I was mistaken"
  #4 (permalink)
Old 09-09-2007, 11:22 PM
thanks for the info. I'm gonna check out a place called Malemberg Truck and Trailer they do a lot of work on big rigs and heavy equipment. They made my custom leaf springs and I had really good service so I'm gonna give em a call.
I'll post the results for anyone that's interested.
Thanks
Ness
Tags
06, 77, custom, driveshaft, drivshaft, f150, f250, ford, malemburg, trailer, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
