94 turbo idi bad mileage and doggy
I have a 94 7.3 idi turbo. I am getting about 11mpg on the highway or in town. I pulled a empty car hauler out of town and got about 6-7mph and it was hard to pull. I am getting about 8.5 psi of boost. Any help would be appreciated. The truck says it has 103,000 miles on it.
I believe pump and injecters are original
I get the normal black smoke from diesels but i get lots of whitish blueish smoke at very low throttle conditions.
I havent checked for exhaust leaks. I will check
What o-rings did you change?
I was planning on blowing out my return lines. Should I just replace them?
i would replace my lines and caps with a kit, they are around for about $30
basic mantanance is good to do but has the truck been timed at all? that can help big time. as the pumps wear they wear to the retarded side. when i had mine timed it went from being down in 3rd (5 sp) on a good hill at 45 to holding in the 70's and no shifting.
on
Unless you are seeing high oil consumption, I would tend to agree about timing being a possibility.
If, however, you are seeing oil consumption, then I would clean the CDR valve by removing it, and soaking it in gasoline for a while.
From what I have heard about the turbo IDIs, there really shouldn't be much black smoke once the turbo spools, so I would check for leaks in the turbo plumbing and intake as well. It doesn't take much, to blead off boost pressure, and the waste gate could be compensating, but overall, the amount of air getting into the engine may not be enough for the amount of fuel, even if you are seeing 8.5 psi.
You'll need a pick with a hook to get under them to get them off
f350custom
16
01-05-2016 02:57 PM
Gen 1 driver
19
03-11-2012 09:36 AM
