Go Back   Ford Truck Enthusiasts Forums > Marketplace > Vendor Specials, Discounts, Product Announcements & Group Buys
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
  #1 (permalink)
Old 08-29-2007, 10:21 AM
AIS AIS is offline
Garage is empty, add now
AIS is starting off with a positive reputation.
Most advanced water injection available!!
We've received several questions about our systems here on FTE. I thought it would help others with similar questions if I posted some info from our website. So here it is
No supercharger or turbocharger system is complete without a water methanol/alcohol injection system. Whether or not you are running an intercooled system, the benefits gained from water injection are so profound you simply can't afford to run without it. The best part is that these benefits can be realized in less than an hour... the time it takes to install our system.
Water Alcohol/Methanol Injection Will Reduce Your Air Charge Temps and Provide the Following Benefits:
Our trunk mount kits make it easier than ever before to install. Unlike other systems, you won't have to worry about assembling the components first and then trying to find space to install the pump, container, hoses and wiring under the hood of your ride (nearly impossible on newer vehicles). This can be time consuming (between 4-6 hours) and costly (mechanics can charge $100+ per hour). Our trunk mount systems are typically installed in less than an hour!! That's because our system comes pre-assembled. So the only thing you'll have to do is install the tank assembly, injection nozzle, and the fluid lines connecting the two. You WON"T need to remove your bumper or fabricate mounts in your fenders!! We even provide you with REAL installation instructions, not some generic steps that were haphazardly put together.
Compare our trunk mount systems to the competitors systems and you'll quickly see the difference!
Our Kit vs. Leading Competitors:
  • Most advanced digital progressive controller on the market - compare for yourself vs. the competitors
  • Our all-in-one controller allows you to run not only a boost signal but also a MAF, TPS, MAP & EGT signal
  • System includes a serial port for connection to a laptop
  • System comes pre-assembled unlike the competitors which requires you to assemble everything
  • System can be installed in 45-60 minutes - That's 5-9 times faster vs. the competitors under hood kit
  • No unsightly pump, reservoir, hoses or added wiring under the hood
  • No need to convert existing wind shield wiper fluid container
  • Our system is completely hidden in the trunk for a stealthy install
  • 1.5 gallon container vs. the competitors common 1-2 quart container
  • Much less frequent refills required as the leading competitors do
Have questions or need help choosing the right water methanol/alcohol injection system for your application. Gives us a call toll free for immediate service at 1-801.447.ALKY (2559)
Click the image to open in full size.
Stage 1 Adjustable Boost Activated Trunk Mount Water Alcohol Injection System
Stage 2 Adjustable Boost Activated Trunk Mount Water Alcohol Injection System
  #2 (permalink)
Old 08-30-2007, 07:43 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
Founder ... Stay Tuned
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Do you have any customers running this system with Roushchargers on 5.4L V8s?
__________________
The best is yet to come....
  #3 (permalink)
Old 08-31-2007, 09:01 AM
AIS AIS is offline
Quote:
It's not a Roushcharger but I think you may interested in hkiefus' thread over here: http://www.ford-trucks.com/forums/63...finally-2.html
We have customers with roots style superchargers that have installed our system. These superchargers are a great application for water injection because of the high air charge temps they produce. Let me know if you have any questions about our system.
- Nathan
Tags
advanced, injection, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
