New here - Ford Truck Enthusiasts Forums
Ontario Chapter Join Chapter>, Leader: loudfords
New here
Old 08-29-2007, 08:44 AM
lmnr0026 lmnr0026 is offline
lmnr0026 is starting off with a positive reputation.
New here
Hi fellow Ontarians. I've recent picked up an '89 e350 at auction to convert to a camper. More details in the general introductory thread. Nice to see some 'local' representation on the board.
I'm looking to swap out the RA gears for something a little taller, where would y'all recommend I look for parts? I live in Toronto, the vehicle is near Barrie. I checked with Cooksville auto (or Cookstown?) who have done well for me in the past but they only sell the whole rear assembly. I just need the pod.
Back to reading through all the great posts here, and getting generally edumacated on all things ford-truck.
Cheers,
Ron.
Old 08-30-2007, 07:14 AM
fp_5's Avatar
fp_5 fp_5 is offline
fp_5 is gaining momentum as a positive member of FTE.
Welcome to the Ontario chapter....yours to discover
The Barrie automotive flea market is comming up, you might luck out there. Also post what your looking for on our chapter foresale/want ads thread.
Good luck
Frank
Old 09-01-2007, 06:16 PM
Blackstock's Avatar
Blackstock Blackstock is offline
Former Vendor
Blackstock has a good reputation on FTE.Blackstock has a good reputation on FTE.Blackstock has a good reputation on FTE.
If it is any help to you, we have some good pricing on aftermarket and Ford crown and pionions. Example for a '89 Full size Van 8.8" rear, a Richmond 3:73, 4:10 or 4:56 set are $195 and if you need a complete install kit $110 COMPLETE INSTALL KIT INCLUDES - PINION SHIMS, CARRIER SHIMS, CRUSH SLEEVE, PINION SEAL, PINION NUT, RING GEAR BOLTS, COVER GASKET, CARRIER BEARINGS AND GEAR MARKING COMPOUND. 2) THIS IS SAME AS RAYTEC INSTALL KIT PLUS CARRIER BEARING & MARKING.Our supplier has it all in stock next day delivery 5 days a week if ordered by 4PM.
Old 09-07-2007, 10:25 AM
Thanks Jim I will probably be getting ahold of you when I get that far into this project. this is an '98 e350.
The Batmobile Steeple923 General Automotive Discussion 6 01-20-2013 06:01 PM
A brand new (almost) '86 muskeg_mapper 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 03-03-2010 01:46 PM
1950 F100 Truck cab lights 48fordjeffie 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-16-2007 08:47 PM
Toronto Members Jigsaw Ontario Chapter 4 02-20-2004 10:38 PM
51 Ford F1 Deluxe Cab Corry 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 03-21-2000 05:51 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
