Leaky master cylinder & no cruise control
Old 08-29-2007, 06:57 AM
neilc88's Avatar
neilc88
neilc88 is offline
My cruise control stopped working and I see a small leakage of brake fluid on the "recalled wiring harness with fuse." It appears to be coming from the connection point to the master cyclinder. I inspected the 2 Amp fuse in the recalled wiring harness and it was blown. I replaced the fuse but cruise control still does not work. Any thoughts or ideas on the fix?
Old 08-29-2007, 09:28 AM
RACERX7775's Avatar
RACERX7775
RACERX7775 is offline
take the fuse out. and have it repaired. THAT IS WHAT CAUSES THE FIRES!!!!!!
Old 08-29-2007, 09:33 AM
neilc88's Avatar
neilc88
neilc88 is offline
Thanks, to clarify, I took the 2A blown fuse out. Tested the cruise control with a new fuse and it still did not work. Replaced with original blown 2A fuse.
Old 09-09-2007, 09:43 PM
aortizexcursion's Avatar
aortizexcursion
aortizexcursion is offline
neilc88 have you had the cruise control switch recall done, if not you really should. My Excursion almost caught fire I caught it when it was smoking, I disonnected the switch right away, leaked brake fluid for a few months before they finally issued a recall for the Excursions.
Old 09-09-2007, 11:12 PM
RACERX7775's Avatar
RACERX7775
but if its leaking, and not under warranty, will they still repair it?
Old 09-10-2007, 01:43 AM
1's Avatar
1 is offline
I believe you just need a new switch that screws into the end of the master cylinder.
Not sure if my 03 was included in that recall, but i think im gonna go ahead and add a 2 amp fuse to that wire if its not there already.
I'm just amazed ford ran that same switch for so long after it was a known problem on other vehicles. Then they come up with this hack fix for it. They should have redesigned the switch and replaced em all. I guess when teh company is struggling to stay above water this is what you get though.
Old 09-10-2007, 07:50 AM
neilc88's Avatar
neilc88
neilc88 is offline
The recall was performed and that is when I started having problems with the c.c. The X is going back to the dealer tomorrow.
Old 09-10-2007, 02:40 PM
mntg718's Avatar
mntg718
mntg718 is offline
the same happend to my X the cruise control stopped working and i notice a leak from the master cylinder....so the leak of the master cylinder is caused by the cruise control switch that screws into the end of the master cylinder???
Old 09-10-2007, 03:36 PM
1's Avatar
1 is offline
I believe the brake fluid leaks through the switch itself and shorts out the circuit and starts the fire.
Old 09-10-2007, 03:45 PM
mntg718's Avatar
mntg718
mntg718 is offline
it leaks betwen the master cylinder and the hydrobooster
Old 09-10-2007, 05:01 PM
1's Avatar
1 is offline
I thought they stopped using the hydroboost on the brakes a couple years back?
Old 09-11-2007, 06:43 AM
neilc88's Avatar
neilc88
neilc88 is offline
My leak is right where the wiring plugs into the master cyclinder. Its at the dealer now.
Old 09-12-2007, 11:25 AM
neilc88's Avatar
neilc88
neilc88 is offline
The dealer says $110 + tax for a replacement brake switch.
Old 09-13-2007, 07:10 AM
neilc88's Avatar
neilc88
neilc88 is offline
Everything is working now. New brake switch and cruise control works, no leak at master cyclinder.
sccamper
09-23-2017 06:11 PM
Pipeliner_86
12-03-2015 07:01 AM
hawesra
1997-2006 Expedition & Navigator
07-21-2014 08:01 PM
tractoman
07-14-2014 10:21 PM
TPINK
Electrical Systems/Wiring
03-25-2012 01:01 PM
Quick Reply: Leaky master cylinder & no cruise control
