Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 08-29-2007, 06:16 AM
HOTSPOT's Avatar
HOTSPOT HOTSPOT is offline
Garage is empty, add now
HOTSPOT is starting off with a positive reputation.
Thumbs up Bluetooth Handsfree Addon
I have ordered the Motorola T-605 and the professional install kit which is basically a cable that taps into the factory wiring.
I prefer Motorola phones, so this is a good match. From what I have read it is a fantastic unit.
The unit is $130 and the cable is $40.
I'll let y'all know how well it works.
  #2 (permalink)
Old 08-30-2007, 02:59 AM
Monsta's Avatar
Monsta Monsta is offline
2005 Ford Excursion
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
I'd be really interested in your "review" of it!
__________________
Ken
"Socialism, like the ancient ideas from which it springs, confuses the distinction between government and society. As a result of this, every time we object to a thing being done by government, the socialist concludes that we object to its being done at all. " -The Law, Frédéric Bastiat, 1850
  #3 (permalink)
Old 10-01-2007, 02:22 PM
HOTSPOT's Avatar
I was not too happy with it and sent it back. I did not even install it. It required cutting into the harness and I did no want to do that.
I have a Parrot system on the way that is supposed to be plug-n-play with a color LCD for caller info.
I will take pictures of the install and post them along with a review of the unit.
Supposedly, Parrot is the industry leader. We will see!!
__________________
MAD 3 is June 7, 2008 USCG Station Fort Macon
http://www.militaryappreciationday.o...eadersmall.gif
  #4 (permalink)
Old 10-01-2007, 03:08 PM
rjd75 rjd75 is offline
rjd75 is new and has a neutral reputation at this point.
Looks interesting, there is a wiring harness that needs to be installed behind the head unit.. If you feel so inclined please take some pics of the dissassembly so we can see how the stereo pulls out!
  #5 (permalink)
Old 10-01-2007, 08:37 PM
mrtoyman mrtoyman is offline
mrtoyman is starting off with a positive reputation.
I do have the Parrot CK-3200 set-up using a wiring harness that i got from www.parrotkits.com (not affiliated with them). Even with their harness you will still need to hardwire the switched/ignition wire from their harness as it is not supplied from the harness coming the truck. I got the switched power source from the fuse box on the passenger side. I can't remember what number but i can find out if you need it.
Hope this help.
  #6 (permalink)
Old 07-12-2011, 03:10 PM
neitz neitz is offline
neitz is starting off with a positive reputation.
Parrot MKi installed, but no Sub
I just installed a Parrot MKi9000 in by 07 w/ Nav, and the phone side of it works great and as intended (sound comes through front speakers). I used the Quick Connect Harness (QCEXP1-MK) and had to tap into the fuse box for the switched power.
However, one of the benefits of the MKi is that it will play your music from your phone using the bluetooth, and while it works, there is no sound coming through the sub. I understand the harness and parrot only taps into the RFLF, RRLR speakers and not the sub. So I am wondering if anyone knows a workaround to get sound to the sub?
Worst part is, the Aux In I used to use with a cable and my phone, now gets switched over to the parrot so I again lose the sub. CD and Radio is fine, but the darn parrot hijacked my aux in. If I would have know I would lose the sub with music, I just would have bought the cheaper parrot for just the phone.
BTW - If anyone has any Q's on the install, feel free to ask as it went pretty smoothly. Thanks!
__________________
Brent
2007 Expedition EL Limited
2002 Explorer XLT
2002 Mustang GT
  #7 (permalink)
Old 08-04-2011, 02:48 PM
Solved my own problem! Posting this here in case anyone else is interested or searches on this topic in the future.
The harness I used (model listed in above post) has two RCA jacks that provide a stereo low level output. So a simple RCA-to-mini jack cable connected from the RCA outs of the harness to the factory Aux In in the Expy dash provided the connections needed to get sound to the sub.
It didn't work at first, but I found there is a setting on the parrot that needs to be changed, called "mute on streaming audio". It's either on or off, and with my parrot model (no display, just the remote), you have to hold in the << and >> at the same time within 30 seconds of the "bongo" chime that you hear during startup. You will hear another tone confirming the change took place.
This stops the parrot from muting your stereo amp, and allows the output through the RCA jacks to be pumped back in to your stereo through your Aux In, and your subwoofer will now be powered with the music from your phone. You will need to select Aux In on your stereo for your music from your phone, but the parrot will still switch your stereo to "Phone" regardless of which input you were using when a call comes in or you hit the call button on your remote to make an outbound call.
I just received my shop manual, so my next step is to figure out the wiring on the Aux In jack behind the dash so I can splice in the RCA outs and get rid of the wire coming out from behind the dash and back in through the Aux In jack.
I got the parrot mainly for the hands free phone, but I must say I enjoy the wireless music even better.
__________________
Brent
2002 Explorer XLT
2002 Mustang GT
Tags
2007, 2008, addon, bluetooth, expedition, f150, ford, free, hands, handsfree, navigation, navigator, older, parrot, setup, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
