Went to the dump today and had my truck weighed before and after but the guy didn't say what it weighed on the way in but after dumping it read 7140 lbs with me out of it and 1/8 tank of fuel. I also have a roll up tonneau cover and a thick rubber bed mat. It's an '06 PSD extra cab 4X4 Lariat, seemed heavy to me, what does yours weigh?
If I remember right my truck weighed in at 7,840 lbs and i rolled on the scales right after the low fuel light turn on. I have a fiberglass SnugTop on my truck.
Cat Scale weighed mine at 8,200 with me (220 at the time) and 46 gallons of fuel. This was before the bumpers, winch, toolbox and tools, and 35" tires.It's overdue for another trip to the scales!
I had mine weighed with only the front tires on the scale and then with only the rear tires on the scale. I did this so I could figure out the correct tire pressure. The total weight should be these 2 numbers added together. 7,490 lbs with no load, no passengers and about 1/2 tank of fuel.
2001 F250 SD SC shortbox 4x4. 6450lbs full of gas and no one in it. Certified truck scale where I work. My travel trailer weighs 6500 as I pull it (loaded for camping).
