You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Works as advertised. I disabled mine so I don't have to hear that annoying dinging while I am getting hooked up, or just cruising around the campground.
One time disable
Any time the safety belt is buckled and then unbuckled during an
ignition ON cycle, Belt-Minder_ will be disabled for that ignition cycle
only.
Deactivating/activating the Belt-Minder_ feature (if equipped)
Read Steps 1 - 4 thoroughly before proceeding with the
deactivation/activation programming procedure.
The driver Belt-Minder_ feature can be deactivated/activated by
performing the following procedure:
Before following the procedure, make sure that:
The parking brake is set
The gearshift is in P (Park) (automatic transmission)
The ignition switch is in the OFF position
The driver safety belt is unbuckled
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1
minute)
Step 3 must be completed within 50 seconds after the safety belt
3. At a moderate speed, buckle then unbuckle the safety belt 9 times,
ending in the unbuckled state. (Step 3 must be completed within 50
seconds after the safety belt warning light turns off.)
After Step 3, the safety belt warning light will be turned on for three
seconds.
4. Within approximately 7 seconds of the light turning off, buckle then
unbuckle the safety belt.
This will disable the Belt-Minder_ feature for that seating position if it
is currently enabled. As confirmation, the safety belt warning light will
flash 4 times per second for 3 seconds.
This will enable the Belt-Minder_ feature for that seating position if it
is currently disabled. As confirmation, the safety belt warning light will
flash 4 times per second for 3 seconds, followed by 3 seconds with the
light off, then followed by the safety belt warning light flashing 4 times
per second for 3 seconds again.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Fordฎ is a registered trademark of the Ford Motor Company.
