400 Thermostat?
Old 08-28-2007, 07:52 AM
Nigel's Avatar
Nigel
Nigel is offline
400 Thermostat?
I have looked every where for a ford or other locally available part number for the right thermostat for a 78 400. Can someone come up with it or an application that is known to have the right thermostat?
Thanks
Old 08-28-2007, 09:16 AM
1978Crew's Avatar
1978Crew
1978Crew is offline
these guys have the correct thermostat.
www.flowkooler.com
Old 08-28-2007, 01:38 PM
Nigel's Avatar
Nigel
Nigel is offline
so there is no way of getting the right part from napa or car quest??? I know I saw a correct ford part number a long time ago but can not find it anymore. If I remember correctly it was a cleveland application but I don't know.
Old 08-28-2007, 03:13 PM
dustinova's Avatar
dustinova
dustinova is offline
I'm in the same boat Nigel. It's hard to believe that the only place I can get a correct T-Stat for my truck is online (and at a pretty shady website at that). Is the correct one available at a dealership?
Old 08-28-2007, 10:08 PM
fatherdoug's Avatar
fatherdoug
fatherdoug is offline
A ford dealer will sell what they say is the correct thermostat, but it does not close off the internal bypass on the 400 engine.
Another bet might be to find a distributor that sells a Mr Gasket thermostat which also has a correct application for the 400. I got mine from flowkooler, part #333-192, and I had no problems with the ordering or delivery. Jeff's Bronco Graveyard also sells them.
Old 08-28-2007, 10:23 PM
madrockwyo's Avatar
madrockwyo
madrockwyo is offline
here is an old thread on this topic that gives all sorts od good information and parts numbers
https://www.ford-trucks.com/forums/4...questions.html
79f1501ton
28
10-26-2019 01:07 PM
TMI
06-02-2017 02:20 PM
TMI
12-22-2016 10:13 AM
POPAJON
11-21-2012 08:42 PM
53fatfndr
53
11-17-2007 07:04 PM
Quick Reply: 400 Thermostat?
