Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 Performance Ford F-150's
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 08-28-2007, 07:23 AM
'03FordSVT is starting off with a positive reputation.
Bogging/Stuttering after 3,000 RPM
I've been running into a problem these last couple of days. If I put my foot down it pulls hard up to 3,100 RPM and justs stops accelerationg and makes a loud bogging/stuttering noise. Im trouble shooting that it could come to 2 problems. Poor Fuel Quality or my Fuel Filter is clogged and not letting enough Fuel through to the motor. Has anybody else had this problem?
Thanks for the help!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 08-29-2007, 07:12 AM
Anyone?????????????????
  #3 (permalink)
Old 09-03-2007, 03:41 PM
fast83 is starting off with a positive reputation.
man it definatly is a fuel problem but with fuel injected I am not sure is the truck stock jive me a list of mods and maybe I can help from there
__________________
393W 286Xr solid roller cam kit 1969 block Melidon 8 quart pan TFS heads 288CFM stud girdels trick flow push rods Vic Jr ported 920 modified Holley dual stage nitrous kit TCI 3500 stall C-6 9" w/ 4.56 Mark William Posi unit 31 spline axels custom "X" pipe 3" Hurst pro-matic shifter
  #4 (permalink)
Old 09-03-2007, 08:41 PM
2003...K&N Intake & Borla Cat-Back. Thats It's. Motor is bone stock.
Yesterday I was driving it and I was at a red light. Once it turned green I pinned the throttle, Ran really strong al the way up to 60MPH(no problems) As I was driving home I was merging into faster flowing traffic and hit pinned it again and started to bogg out on me after 3K-4K RPM. I mean it's not happening all the time. Sometimes it pulls like Hell then other times its like the Supercharger is slipping. Could it be my Belt/Pulley?
  #5 (permalink)
Old 09-03-2007, 08:48 PM
wd13's Avatar
wd13 is gaining momentum as a positive member of FTE.
What mods do you have done? I've seen and had issues with a # of things myself each acting in the way you are describing. Your mod list would help me narrow it down.
Nevermind, I see your mods
  #6 (permalink)
Old 09-03-2007, 08:50 PM
wd13's Avatar
Miles? Have you noticed outside or engine temp having any effect?
  #7 (permalink)
Old 09-03-2007, 09:14 PM
It has 43,000 Miles. Engine Temp is Normal. If I just cruise around town under 2,500 RPM you can tell anything is wrong. But if I slowly apply 3/4 or full throttle it wont bog. It justs bog when I step on it. Im going to clean out my air filter tommorow to see if it helps.
Any other ideas?
Let me add some more info...."This truck has been baby'd since my dad bought it in '03. This truck rarley even went over 3,000 RPM." So its not driven like it was stolen.
  #8 (permalink)
Old 09-03-2007, 10:24 PM
wd13's Avatar
First off I'd start with the simple stuff ie. spark plugs, fuel filter. At 43000 miles both are in need of changing anyway. If this doesn't cure it, I'd be looking into fuel issues. I'd check fuel pressure (should be around 39psi idle and 50ish WOT) and also, its common for the T on the fuel line at the tank to go bad causing this very sort of problem. It would be something to check. I've even seen one of the converters plugged up causing this very sort of thing although I'd say that its unlikely. Hope this helps, I know its a pain but maybe this will get you started.
  #9 (permalink)
Old 09-04-2007, 06:12 AM
I'll probaly start with my Spark Plugs. And se how it runs after.
What kind of plugs are needed?
  #10 (permalink)
Old 09-04-2007, 09:30 AM
huitt24 is starting off with a positive reputation.
what you are describing sounds like a COP going bad. I have had this happen 3 times. Truck runs great till about 3K or when getting into boost then the exhaust note changes and sounds like it is bogging down, let off the gas to get out of boost and it runs great. If your plugs look fine then I would look at the COPs next.
__________________
2004 XLT Screw 5.4L 1/4 14.66 @ 95MPH
390 RWHP 446 RWTQ
Ground Force 2/4 drop, Roush IC SC
GMS COP's, Pace Setter LT's
magnaflow cats, x-pipe, DI/DO muffler
Hellwig rear sway bar, Custom Traction Bars
2005 SCAB 5.4L 3.73LS 2wd Roush 20's
magnaflow x-pipe/DI/DO muffler, true dual exhaust
  #11 (permalink)
Old 09-04-2007, 09:35 AM
i am a non lightning owner but I here a lot of raves on the NGK's one degree colder I would doubt it is your belt slipping that would be more of a significant loss of power not a bog but if it is the origanal I would replace it. If it were me I would do a tune up on it plugs wires filter and oil I would even clean your Mass air sensor I hear of them getting dirty and cause a loss of power similar to the one you talked about. Then drive it and see if that helped (not like it would hurt to do this at 43,000 anyway) then I would look into the 2 or three fuel filters and that "T" in the tank. you should be fine from there if not I would have a diagnostic ran on it you might want to go ahead and replace the fuel pump (possibly go warbrol pump) while in the tank another couple of dollars and about 5 more minutes
__________________
  #12 (permalink)
Old 09-04-2007, 09:40 AM
Quote:
I know a lot of DIRTY COPS but I doubt you are talking about a different kind of bad COP anyhow I have a carbs motor so I am not so understanding the COP what is that. If he would have told me the same thing with a Carb motor I would have told him to put a hose between the two vents on the carb anyhow want to know more about the fuel injected motors
__________________
  #13 (permalink)
Old 09-04-2007, 09:45 AM
Quote:
COP = Coil On Plug, the L's will have 8 individual coil on plug, where as the old carb's only have one for all 8 cylinders.
__________________
390 RWHP 446 RWTQ
  #14 (permalink)
Old 09-04-2007, 09:59 AM
yes I understand like the LS-X motors I was unaware that the lightnings also had this
__________________
  #15 (permalink)
Old 09-04-2007, 02:50 PM
So what is the solution to the problem? Just slap on some new plugs?(I hope)
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
