Hard Shift w/ Tuner
Hard Shift w/ Tuner
Anyone have this experience or advice: With my DP Tuner, on occasion, when accelerating pretty hard it will "bam" slam into the next shift. Doesn't do it without tuner. Never does it either way when driving and accelerating normal. I don't get on the pedal much but, like I said, once in awhile when I need to accelerate to pass or merge... "bam" on the high shift. The tranny had only 5K on it when I bought the truck last December with 175K. I'm afraid I'll damage the tranny. I've been in contact with Jody and waiting to hear back. Again it is rare and often doesn't do it. ????
Rich
I second the valve body, best thing I ever did. I used to cringe every time it was going to shift because I knew at a certain throtle/acceleration limit it was going to shift hard. Now the shifts are all crystal clear/firm. Not hard mind you in case you are wondering. The best way I had it explained was that it shifts like it should have from the factory.
Originally Posted by 15 and 92 Dad
Yes, I had the same problem!!!! I have the D.P tuner and used to have the banks trans command, With the trans command hooked up and the D.P my truck would shift SO HARD I thought it was going to tear the rear end OUT!!! I removed the trans commmand, it shifted better but still to hard. Last week I purchased the BTS valve body and plate, removed the trans command and Bingo, Thats it, shifts GREAT, firm like it should but no BANGING into gear now! Yes it still gets rubber when shifting to 2nd but its a firm shift, NICE, I HIGHLY recomend getting the BTS or equivelant valve body and plate!
Rich
Rich
yea true i think theres something wrong with my tranny now tho every morning leaving for work i start it up put it in reverse and then it doesnt liek really shift into reverse it revs up and then it will start backing up slowly but then its fine.. also when im at WOT it shifts into 2nd really hard third it feels like my gears are spinning then WAM it slams into third i gotta get it looked at i think i had the tranny replaced at 40k already
