Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 vanSPONSORED BY:
  #1 (permalink)
Old 08-27-2007, 11:07 PM
emmagator's Avatar
emmagator emmagator is offline
Garage is empty, add now
emmagator is starting off with a positive reputation.
Rotella vs Mobile 1
I can get either Rotella 5w-40 full syn for 16$ or Mobile 1 5w-40 full syn for 22$. Is it worth paying extra for Mobile 1? What do you guys think??
  #2 (permalink)
Old 08-27-2007, 11:22 PM
04Xcursion's Avatar
04Xcursion 04Xcursion is offline
04Xcursion is starting off with a positive reputation.
Honest answer is run the Rotella, I personally run Mobil Delvac 1 5w40 and have had no issues but I couldn't say in good faith that it is any better than the Shell. I know many others here have had great success in running the Rotella.
  #3 (permalink)
Old 08-28-2007, 06:17 AM
bismic's Avatar
bismic bismic is offline
bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.bismic has a spectacular reputation.
Quote:
I have recently read a couple of articles that talk very highly of Shell Rotella T Synthetic 5W-40 (not the Rotella T Triple Protection). It is a full synthetic so it has a good base stock (it is Group III or maybe a Group IV - someone else can fill you in on this) AND the additive package has been highly reviewed. Seems to be a VERY GOOD oil for a very reasonable price and it is readily available. Lots of folks here use it and recommend it.
Interestingly enough, it is also highly recommended in severe motorcycle applications due to the high detergent content (necessary for diesels) and the anti-wear additives.
That being said, I have read that the Mobil 1 is good also. I just haven't seen anyone really brag on it.
__________________
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
  #4 (permalink)
Old 08-28-2007, 09:17 AM
emmagator's Avatar
Im currently running Rotella, but am now able to get Mobile 1. Just wondering if I should switch
  #5 (permalink)
Old 08-28-2007, 10:10 AM
origcharger origcharger is offline
origcharger has a good reputation on FTE.origcharger has a good reputation on FTE.
Well you can save $6 per and you know how to spell Rotella
Seriously, we run Rotella and see no reason to switch.
__________________
2004 E-450 6.0 180,000 miles
7,500 mile, 15 quart changes, 5W-40 Syn.
UOAs consist of checking for metal on drain plug magnet. Dyed ULSD fuel with no additives. Never been reflashed. Total parts replaced; one turbo,
two EGR valves, forgot to reconnect the wires on the second one at 151,360 miles.
  #6 (permalink)
Old 08-28-2007, 02:23 PM
pstrang pstrang is offline
pstrang is starting off with a positive reputation.
I've run Rotella-T Syn 5W/40 for a couple years now...I've been happy. But I recently did an experiment to see if the Mobil 1 Turbo Diesel 5W/40 was worth the extra cost. "Wow" is all I can say. It is a better oil, a higher class of full synthetic. The truck runs noticeably smoother. I'm very tempted to put it in next time...even at the extra cost.
__________________
2005-6L/PSD F-250 Lariat CC/SB/4x4:
- MBRP 4" turbo back, CCV4500, coolant bypass filter, oil bypass filter, X-monitor, Fluidampr, fuel x-over line, intake elbow, EGR cooler delete w/ welded uppipe, wrapped headers and turbo hot-side.
  #7 (permalink)
Old 08-28-2007, 02:37 PM
LvTitan LvTitan is offline
LvTitan is starting off with a positive reputation.
i run delo 400, but that is mostly because it costs me zero dollars a gallon
__________________
04 6oh... that's where the money went.
  #8 (permalink)
Old 08-28-2007, 06:49 PM
slowmans's Avatar
slowmans slowmans is offline
slowmans is gaining momentum as a positive member of FTE.
i used to run rottella 5-40 but recently switched to mobil 1 this oil change and i did notice th truck does seem to run a little better? my next change is going to be r.p to see how it reacts and because i got a case for 56 bucks!
  #9 (permalink)
Old 08-28-2007, 07:44 PM
Powerstroke_wannabe Powerstroke_wannabe is offline
Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.Powerstroke_wannabe has a great reputation on FTE.
Holy cow!!!! Where can I get a case of RP for $56?
__________________
Frank
2006 F250 Lariat FX4, CC, SB, 6.0 PSD, Torqshift, 3.73 LS, Backseat DVD system, Extreme Bedliner, Westin Bully Bar, Dieselsite Coolant Filter, Fumoto Valve, Accufab Intake Elbow, Bilstein HD Shocks, Smitty-Bilt Grille Inserts, MBRP Turbo Back Cool Duals (Kitty ran away), ICON Dual Steering Stabilizer Kit w/Bilstein 5100 Shocks, Nitto Terra Grappler AT 295/70-R18, Retrax Cover
  #10 (permalink)
Old 08-28-2007, 08:07 PM
slowmans's Avatar
e-bay!!!!!!!!!!!!!!!!!!!!!!!!!!
  #11 (permalink)
Old 08-28-2007, 09:43 PM
Hank85713 Hank85713 is offline
Hank85713 is starting off with a positive reputation.
pepboys is advertising $6 off on 12 qts, but last time I checked it was near $8qt. Anyone know what it prices out at now? It has been praised highly to help in milage along with the RP synthetic gear lube in the diffs and transfer case for 4x's. I was wondering about which is better also as I am going to be doing my own from now on. Dont want to start an oil war, but which is the best synthetic for the PSD?
  #12 (permalink)
Old 08-28-2007, 10:14 PM
bismic's Avatar
Quote:
Lots of previous threads on this. A good place to start is w/ the link below. The TDR review that you access w/ the link did not look at Royal Purple or Mobil 1 or Schaeffer 9000. I am getting a virgin oil analysis of the Schaeffer, just for curiosity. In general, I believe a $3.00 per quart oil changed at 4000-5000 mile intervals is better than an $8.00 per quart oil changed at 7500. The viscosity characteristic of the oils drop off pretty quick after 5000 miles in these 6.0L engines.
http://www.turbodieselregister.com/a...lem/Page1.html
__________________
Mark
  #13 (permalink)
Old 08-28-2007, 10:18 PM
bismic I know, I tried mob 1 in my goldwing and at about 3500 it was hard to shift etc. Of course it had a trailer to pull and me and wife. But I am willing to spend a little more to improve overal milage and like I said RP has had good reviews just dont know if it worth $8/qt vs the $22/gal mobil 1 or the other at wm for $16.
Thanks for the link
  #14 (permalink)
Old 08-28-2007, 11:09 PM
bismic's Avatar
Thanks for the link
Another link I found ........
Mobil-1 automotive oils all contain small amounts of moly - about 100 to 200 ppm. This can cause clutch slippage in wet sump applications in some motorcycles. I've only heard of this being a problem in Honda Shadows.
__________________
Mark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
