IDI turbo IP vs. NA IP
Talked to my local diesel shop about a new turbo injection pump and turbo injectors. As you know many websites out there charge a little extra for a turbo pump but this shop sells them turbo or not for $425 exchange. When I asked them about the difference (also whether they would take my NA pump in exhance for the turbo pump), they told me that all the pumps are the same internally but the turbo pump is just turned up from the factory. Is this the case? If so I'm gonna shop for a better price...Thanks for the imput.
-Dave
-Dave
I think that the 7.3 injector pumps have bigger diameter High Pressure plungers, also the turbo pumps (93 up) had an extra adjustment screw on the back of the pump that is a max fuel stop for the metering valve arm on the governor. Allows for easier max fuel adjustments for the turbo application rather than pulling the side cover off the IP to get at the max piston travel screw.
The DB2- 5028 is the right pump for a 92.5 thru 94 NA 7.3 with an automatic tranny.
I think the only difference has something to do with the FILP to control the automatic tranny.
It has been a while since I saw one of each setting side by side, but I seem to remember something a bit different where the FILP sits.
I sure would like to see a diagram or picture of the two to see what the exact difference is . - Thanks
DB2-5013 - 1992-1994 manual tranny
DB2-5028 - 1992 -1994 auto tranny
DB2-5069 - 1993 -1994 turbo auto tranny
DB2-5070 - 1993 - 1994 turbo manual tranny
All of these injection pumps should have the external fuel adjustment screw.
Perhaps it's an easy upgrade?
Look at the bottom of the h in fuel shut off solenoid.
The h is sort of wrapped around the external adjustment.
Sorry the picture is not a very good view of the screw.
I have been meaning to take a better picture, but the air cleaner housing has to come off to see it.
Not enough hours in a day for me right now, so that is on a back burner for a while.
Since the screw goes to the governor, it would not be an easy mod.
Would you by any chance know which one of those pumps would work on my 87 6.9? I know I'm going to be changing it in the future as it leaks out of the advance plunger on the bottom and the external fuel adjustment would be a nice feature to have. I hate pulling the cover on the front to make sure the screw is at the opening and then pulling the cover plate off the side of the pump to turn it up.
I should have given more info when I asked. My 87 has a Hypermax pulse turbo on it . I took your advice and wrapped both feed pipes and the outlet pipe with heat wrap to build more boost and prevent a repeat of a hole melting in my bellhousing. I think the massive overheat happened when the block heater came out and I lost all my coolant.
Macrobb
32
08-17-2021 09:30 AM
rterril02
06-01-2016 07:42 AM
LordKamakazi
05-05-2016 11:51 PM
crunky944
03-13-2016 11:30 AM
Onus
18
10-04-2012 07:39 PM
