v10 fuel mileage - Page 2 - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
v10 fuel mileage
Old 08-28-2007, 07:08 PM
bing-bing bing-bing is offline
bing-bing is starting off with a positive reputation.
My lie-o-meter seems to read 0.2 tenths higher then my wife's hand calculations. Our 1998 expedition seemed to run about0.2 to 0.3 tenths higher then hand calulating. this is over the last 5 years.
Old 08-28-2007, 07:41 PM
ZBeeble's Avatar
ZBeeble ZBeeble is offline
ZBeeble is starting off with a positive reputation.
Don't forget the whole lawsuit thing about gas stations and temperature corrections. The density of gas when you buy it is not necessarily the density of the gas when you burn it --- so therefore, the hand calculation and the lie-o-meter could both be accurate --- the hand for what you bought, and the lie-o-meter for what you burnt.
Old 08-28-2007, 07:52 PM
jackrista's Avatar
jackrista jackrista is offline
jackrista is starting off with a positive reputation.
00 v10 4x4 104000 on it now had it a few months in the hills of cali i get 10-11 mpg have not done enough towing to calculate a tanks worth. just be easy when pressing on the gas there is no need to past half throtle.
Old 08-28-2007, 10:04 PM
1948f1 1948f1 is offline
1948f1 is starting off with a positive reputation.
16 mpg is very possible with the v-10. I have easily reached that on two highway trips since buying mine this past April. Keeping it at 65-70mph on flat to rolling hills. This is with a family of four and luggage.
If you have to get your foot into it or are hauling a lot of gear you can forget it. I routinely get 11-12mpg around town.
All calculations done by hand. My display routinely calculates .02 high.
Old 08-28-2007, 10:40 PM
ZBeeble has a good point..I still get my trucker magizines and there is ALOT of talk about hot diesel. When we were still driving team a few years ago nobody had even heard of it... Wonder how long the oil companys have known about it?.......
Old 08-29-2007, 02:53 AM
Move over I'm coming Move over I'm coming is offline
Move over I'm coming is gaining momentum as a positive member of FTE.
There has been alot of talk about the calibration of standard measures in fuel pumps lately. I believe the standard here in Minnesota is at 60deg. This is the underground temperature so you don't want to fill after that tanker visited at 4:00 on a 95deg. day or worse. Hot fuel sucks your paycheck big time.
You are supposed to get the most for the money asap in the AM. The tank has cooled down and all fuel bubbles/foaming has settled over night. The oil companies know about this and can't lower the calibration on the pumps as this it a regulation standard unit and is tested annually and certified on all pumps. (stickers of state weights & measures board)
Remember: We get more when it gets cold out. Or so the story says.
Regardless , Move over...... , Rich.
BTW - average 12.5mpg highway , 10.5 Towing travel trailer ,11 Mixed (everyday)
2002 Ex 4X4 6.8 V10
Old 08-29-2007, 05:01 AM
bobalonius's Avatar
bobalonius bobalonius is offline
bobalonius is starting off with a positive reputation.
I have a 2000 4x4 V10 Excursion. I just finished a trip from Columbus, OH to Chicago abd back. On paper I got 15.1 mpg. I didn't reset the meter before I left, but it seems to be pretty consistant at showing .5 mpg more than what I calculate on paper.
Old 08-29-2007, 07:17 AM
one_wicked_element one_wicked_element is offline
one_wicked_element is starting off with a positive reputation.
See my sig for my truck, plus I have 3.73 gears. My truck is my Daily Driver. Going to work is usually a 50-65mph drive, with some stops along the way. I am currently seeing 12.5 to 13mpg.
When I first got the truck, I was running the A/C full blast, taking of like a bat out of hell, and just getting on the truck. I ended up with 9mpg. I don't drive it like it's a Camaro anymore.
I don't have a lie-o-meter, so I do it all by hand. My goal for the truck is to one day hit the 15mpg for my drive to work. I think with some exhaust mods, and other things, I might be able to. Sure, the cost to get it there will out weight the good, but I'd love to say I get 15mpg all the time.
As for towing, and highway driving - nothing to report yet. I only did one jog on the express way for a half tank of gas, mixed with very in-town driving (35mph). It was just over 14.5mpg.
Old 08-29-2007, 08:45 AM
WJC WJC is offline
WJC is starting off with a positive reputation.
i get about 10 to 11mpg in the city, easy on the peddle, and about 15.1mpg on the highway at 72mph@2000rpm. anything past 72mph and 2000rpm my mileage drops off. this is also on flat land which is most of southern nj highways. i also have a few performance mods--see below.
Old 08-29-2007, 10:45 AM
MarkMoore's Avatar
MarkMoore MarkMoore is offline
MarkMoore has a great reputation on FTE.MarkMoore has a great reputation on FTE.MarkMoore has a great reputation on FTE.MarkMoore has a great reputation on FTE.
Quote:
Originally Posted by F250_
Well, Mark, I will say that when you see gas ready to flow out the top of hte fill neck, and do that at every fillup, you can fill your tank more accurately than the OEM meter can calculate. My basis is the fact that there are some assumptions built into the meter's calculation regime that can change based on driver, geography, driver's mood, etc. That's why I always use only hand calcs myself, because I fill up until I can see the fuel... that way I know that I'm getting the same amount of fill, regardless of which station or pump I use.
There are obviously some folks who get very good and consistent results with the meter, but my own experience hasn't proven it to be reliable for me, and most who compare it to hand calcs find the same to be true for them as well. Again, though, I don't doubt at all that it does work for some, like yourself and a few others here who say they have verified it for themselves.
I was just reoprting my experiences and opinion. But since you brought it up, you said the OEM meter is making some assumptions and you're right - but when you calculate by hand you're also making some assumptions, like that the pump displayed the correct amount, your speedo is accurate, your truck was nice and level at the time of the fill up, and as ohers mentioned, the gas was cool and bubble free.
When you think about it - @ 44 gals of fuel, if the pump is inaccurate by +/-1%, then your off by almost 1/2 gal (+/- 0.44 to be exact). Now let say that you're getting 12 mpg and you refill after 480 miles, when you calulate you could be off by as much as +/- 0.15 mpg (you should have gotten 40 gallons, but that 1% could put at 39.5 or 40.5, depending on the + or -). Now if you throw in your speedo being +/- 1%, you've just increase the variance and your mileage could be +/- 4.8 from the actual odo.
There are just so many variables that come in to play for both methods, hence the reason the goverment chose the term "Estimated MPG".
So my point was that I felt mine was close enough for me to depend on - but I still recheck it from time to time when were on trips.
Old 08-29-2007, 12:45 PM
F250_'s Avatar
F250_ F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
You're right, Mark. Only thing is that all the variances you refer to are in addition to the assumptions made by the OEM meter. I always eliminate my speedo issue by checking it against at least 30 miles of interstate when I can stay on cruise at a single speed the entire time, and then repeat that on at least 2-3 different sections of interstate to determine my speedo's accuracy ( I know, I know, that also includes assumptions about stop watch accuracy and mile post location accuracy).
Seems like we just can't get away from assumptions!!
Regardless, like I said earlier, I'm glad that your meter seems to be more reliable than most, since it simplifies your ability to track your mileage. Ultimately, I don't even have the option with my truck, so, on a daily basis, I'm stuck with my hand calcs regardless of assumptions.
Old 08-29-2007, 06:15 PM
boomhower boomhower is offline
boomhower is starting off with a positive reputation.
If you know someone with a GPS either vehicle mount or handheld, that would give another avenue of checking you speedo.
2009 V10 Fuel Mileage RSB Modular V10 (6.8l) 40 08-28-2009 09:36 PM
For the kids what is the mileage on a V10? vettdvr 1999 to 2016 Super Duty 17 09-11-2007 12:51 PM
Fuel Mileage chandlerbf 1999 to 2016 Super Duty 6 07-28-2004 06:09 PM
Fuel Mileage ?s Stampede Excursion - King of SUVs 28 01-12-2004 03:12 PM
V10 Mileage Jetfixr Excursion - King of SUVs 3 11-11-2002 11:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
