05 Expedition trailer brake wiring
I just picked up an 05 expedition xlt with factory tow hitch and 7-pin and 4-pin plugs. Question: I assume there is a factory plug under the dash for trailer brake controller. Is this as easy as purchasing a wiring adapter and then plug in? Does the factory wiring have the necessary 20A circuit breaker? I have a Drawtite Activator that I had on my last rig and am looking to install here.
Jeff
Jeff
The brake controller should be plug and go no matter what. Ford puts a 30 amp fuse in the big panel under the hood, but it's easily swapped out for a breaker if you want.
If you want the backup lights and trailer battery charge pins to work on the 7-way, you may or may not need to get ahold of two relays. Those are in your power distribution box under the hood as well. When trucks are ordered with the trailer towing package, Ford puts the relays and a brake control pigtail in a little bag in the glovebox. Sometimes the dealer will just pop the relays in right off the bat.
i have an 03 expy, it's a class 4 hitch. Rate to just ove 8,000 lbs i think.
here is my manual's info:
Your vehicle is equipped with heavy duty trailer tow wiring. An electrical
connector is provided under the instrument panel for installing a
customer-supplied electric brake controller. A Class I (4–pin) electrical
connector and Class II/III/IV (7–pin) electrical connector are provided at
the hitch. These connectors provide power to the trailer for taillamps,
stop and turn lamps, back up lamps, battery charge, electric brakes
(when a customer provided controller is installed) and ground. A kit
containing a wiring harness/adapter and installation instructions to attach
an electric brake controller may be obtained from any Ford or
Lincoln/Mercury dealer (part number 2L1Z–14A348–AB). Before towing
a trailer, make sure the trailer brakes (if equipped) and lamps are
properly connected and functional. Refer to the brake controller
instructions to check for trailer brake functionality.
Brian Black
07-04-2017 06:07 PM
bossgobbler
10-27-2011 08:18 PM
mjolly5150
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-07-2006 02:53 PM
flyloki
08-28-2002 06:26 PM
2004, 2007, brake, connector, controller, electric, electronic, expedition, f350, ford, install, installation, instrument, panel, pigtail, trailer
