05 Expedition trailer brake wiring - Ford Truck Enthusiasts Forums
Old 08-26-2007, 05:45 PM
dogzpaws dogzpaws is offline
dogzpaws is starting off with a positive reputation.
I just picked up an 05 expedition xlt with factory tow hitch and 7-pin and 4-pin plugs. Question: I assume there is a factory plug under the dash for trailer brake controller. Is this as easy as purchasing a wiring adapter and then plug in? Does the factory wiring have the necessary 20A circuit breaker? I have a Drawtite Activator that I had on my last rig and am looking to install here.
Jeff
Old 08-26-2007, 07:12 PM
grafekie grafekie is offline
grafekie is starting off with a positive reputation.
Yes, it should be ready to go as far as the cab-end.
Old 08-26-2007, 08:10 PM
bigredtruckmi's Avatar
bigredtruckmi bigredtruckmi is offline
bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.bigredtruckmi has a spectacular reputation.
On our 04 there was a wiring harness in the glove box when new that plugged in under dash by radio.
Old 08-27-2007, 12:48 AM
Cowboy Brett's Avatar
Cowboy Brett Cowboy Brett is offline
Cowboy Brett is starting off with a positive reputation.
The brake controller should be plug and go no matter what. Ford puts a 30 amp fuse in the big panel under the hood, but it's easily swapped out for a breaker if you want.
If you want the backup lights and trailer battery charge pins to work on the 7-way, you may or may not need to get ahold of two relays. Those are in your power distribution box under the hood as well. When trucks are ordered with the trailer towing package, Ford puts the relays and a brake control pigtail in a little bag in the glovebox. Sometimes the dealer will just pop the relays in right off the bat.
Old 08-28-2007, 12:43 AM
Thanks for the information. The pigtail does not appear to be found. Any idea on how I would know if the relays are installed or not? I was going to get an aftermarket pigtail, sounds like I need to check with the parts dept at my local dealer.
Jeff
Old 08-28-2007, 01:15 AM
One more question: the hitch on the Exp appears stock and it has the 7-pin and 4-pin plug connectors. Does this mean I have the HD towing package or did that come with all Exp? How do I determine if I have the HD towing package?
Old 08-28-2007, 08:07 AM
wrenchturner wrenchturner is offline
wrenchturner is starting off with a positive reputation.
i have an 03 expy, it's a class 4 hitch. Rate to just ove 8,000 lbs i think.
here is my manual's info:
Your vehicle is equipped with heavy duty trailer tow wiring. An electrical
connector is provided under the instrument panel for installing a
customer-supplied electric brake controller. A Class I (4–pin) electrical
connector and Class II/III/IV (7–pin) electrical connector are provided at
the hitch. These connectors provide power to the trailer for taillamps,
stop and turn lamps, back up lamps, battery charge, electric brakes
(when a customer provided controller is installed) and ground. A kit
containing a wiring harness/adapter and installation instructions to attach
an electric brake controller may be obtained from any Ford or
Lincoln/Mercury dealer (part number 2L1Z–14A348–AB). Before towing
a trailer, make sure the trailer brakes (if equipped) and lamps are
properly connected and functional. Refer to the brake controller
instructions to check for trailer brake functionality.
Old 08-29-2007, 12:19 AM
Thanks for the info. Think I'm good to go. I'll get a harness and try it out this weekend with the trailer.
Anyone have recommendations on where to mount the brake controller?
Old 08-29-2007, 06:59 AM
Somewhere semi-level (not completely verticle, not completely flat), within reach, that doesn't block the diagnostic port and doesn't get in the way of your legs.
Old 09-01-2007, 12:02 AM
Thanks all. I got a new harness with the appropriate relays/fuses. Looks like its plug and play. Thanks for all the info.
Expedition 7 pin round connector question. johnkn Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 5 11-13-2014 07:52 PM
Wiring a Trailer Tow Battery jonesn4fun Electrical Systems/Wiring 1 10-24-2011 08:06 PM
2004 Expedition trailer light issues, blinker and brake lights inop. cecoen 1997-2006 Expedition & Navigator 1 07-20-2007 09:36 PM
Need Help With Trailer tow battery charge relay mjolly5150 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 5 09-07-2006 03:53 PM
Is there factory trailer wiring on 1994 F-250? flyloki 1987 - 1996 F150 & Larger F-Series Trucks 2 08-28-2002 07:26 PM
Tags
2004, 2007, brake, connector, controller, electric, electronic, expedition, f350, ford, install, installation, instrument, panel, pigtail, trailer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
