Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-25-2007, 03:44 PM
imlowr2's Avatar
imlowr2 imlowr2 is offline
Garage is empty, add now
imlowr2 is gaining momentum as a positive member of FTE.
Is this an econline steering box?
I have this box installed in my 56 Ford F100 truck. I've been trying to find out what this box came out of. The box has an S on the side, which I'm told is a Saginaw box. I've also been told this might be from an econoline van? Anyone seen a box like this or know what it might be?
Click the image to open in full size.
__________________
If your not going to do it right the first time, don't do it at all.
  #2 (permalink)
Old 08-26-2007, 10:20 PM
66gpw's Avatar
66gpw 66gpw is offline
66gpw has a good reputation on FTE.66gpw has a good reputation on FTE.
Its not from 61-67 Econolines. They have a steering shaft that is also the worm gear in the box. No breakaway rubber. Maybe a newer econoline from 68-75.
Also the early Econolines the steering arm goes out the side of the box to a pitman arm that then goes down to the trailing arms and the tie rod for the left wheel.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
