can i pull from my bumper?
truck is a 97 old body f350.
i was flipping through the owners manual the other day, and i read through the section on towing. i found out that my truck's bumper is rated as a class III for towing. i cant remember exactly what the weight is, but from the underside, it looks super beefy. its just the stock step bumper. it looks like its built in a way where you could seperately remove the chrome sides and still have the step/hitch ball area tied into the frame. im only looking to use it to be pulled out/pull others out. i wanna put a 1" clevis through the hitch ball hole, and since that part is tied into the frame, it looks like it would be strong enough. what do you think? heres some pics so you can get the idea.
http://i15.photobucket.com/albums/a3...umper2edit.jpg
http://i15.photobucket.com/albums/a3...ro/bumper2.jpg
Well, its a piece of 12" structural C channel cut down to 8 inches in the middle, tapered down to 4 on the ends. The c channel is probably 3/8 thick or a 1/4 thick on the front and top, and the corner is a good 5/8 thick. Then i took 2 40 000 pound rated weld on d rings and put them right in front of the frame rails. triple passes with the Beta mig turned all the way up. On the rear I did the same thing only I has a 2" reciever dead center.
Lets just say I've done some serious shock load testing with them.
RZAR
1999 to 2016 Super Duty
50
05-14-2016 09:39 AM
snaponprofile
33
02-07-2012 01:29 AM
secondarychaos
15
08-30-2008 05:33 PM
